Unknown vehicle?
Ford4Life
Vehicle: Ford Mondeo FFV 2.0 145hp
Unknown vehicle?
Post by Ford4Life »
Hello!
I connected my Vgate Mini ELM327 BT Interface to my Mk4 Ford Mondeo FFV 2.0 145hp Duratec and started Forscan, it connected then Forscan said "Unknown vehicle, contact developer".
What''s going on?
Re: Unknown vehicle?
Please email us logs as described on Contact Us page.
Ford4Life
Post by Ford4Life »
I checked the logs and Forscan can't read the VIN code and fails because of that, is it because it's an unmodified ELM327 adapter?
If you mean MS-CAN modification - no, it doesn't affect connection. Unmodified adapter should work fine except that it unable to see MS-CAN modules.
Reading VIN is also not critical for the program functionality, but it is some kind of bad sign that most likely means there are problems with adapter (FORScan cannot read data reliably). This is why we always ask to send us logs - not possible to find an exact reason just by symptom.
Here are threads if 2 most popular (at this moment) china adapter problems:
http://forscan.org/forum/viewtopic.php?f=4&t=21
http://forscan.org/forum/viewtopic.php?f=4&t=22
Ford4Life
Post by Ford4Life »
Here are the log files (attached as a zip file)... tried 2 different computers, same result.
Here's the adapter (link)
log.zip
(2.96 KiB) Downloaded 381 times
Sad to say this but it seems you have this problem:
http://forscan.org/forum/viewtopic.php?f=4&t=22#p840
Ford4Life
Post by Ford4Life »
Oh, bummer, it didn't cost much so not such a big deal, I'll look into another adapter then, thanks for checking tho'.
Maybe people should stay away from the Vgate adapters then?
Ford4Life wrote:Oh, bummer, it didn't cost much so not such a big deal, I'll look into another adapter then, thanks for checking tho'.
We believe the problem is not in the adapter manufacturer but in this v2.1 chip. Adapter manufacturers have no much choice (if they install v1.5 and their competitors use v2.1, they will lose the market). The v2.1 chip works with majority of OBD2 software and nobody care about FORScan project that doesn't make the adapter market. We are afraid that in some short period of time all china adapters on the market will be equipped with this v2.1 chip. When this happens, it will be not possible to purchase a cheap china adapter and use it with FORScan. Although there is some small chance the developers will fix the problem and release v2.2 that will have the problems fixed.
So, our recommendation is:
1. Purchase white-label solutions (OBDLink MX, CanTieCar).
2. If option #1 is not acceptable, try to at least purchase ELM327 v1.5 adapter.
Ford4Life
Post by Ford4Life »
Ok, well it was advertised as "W3LE New Car Auto Diagnostic Vgate Mini ELM327 Interface V1.5 Bluetooth OBD2 OBD" so I thought it was a v1.5 adapter.
I haven't really gotten any readings from anything, I tried some free apps for the phone, they connect but that's about it... no data is being recieved, at least nothing I can trust.
