Ford Edge ELM connection problem
I need help. Who has a Ford Edge and uses Forscan successfully? I can't seem to find an adapter that will reliably connect. I have tried 3 different ones. Need recommendations.
Re: Ford Edge ELM connection problem
I bought a usb Elm from ebay already modified with the can switch for my 2013 Edge Limited. Can't remember the vendor's name. Probably many others out there. No problems since then.
BTW, the new IOS from Apple does not play well with any wireless ELM devices for monitoring with any software.....they know about it.
Thank you for responding. Did you download software/drivers? If so, which ones? I have tried all the drivers I could find. The name of your adapter would be so helpful.
Thank you, Andy. This looks like just what I will need. Now, I just have to decide on which ELM327 USB to get. Maybe it shouldn't matter if i can get the drivers right.
