Hi guys.
Can someone who did this procedure write down all instruction steps by steps what forscan asked for during this learning?
Big thanks for this! that really fix my mondeo PS 1.3.5 gears clutch working. problem is that when drive stable throtle, rpms litle change. and now problem go away
chrishatred
- Vehicle: Focus MK3 2017
Do i have to hold the gas pedal the whole procedure or just at the beginning?
The instructions are a bit unclear to me...
Throttle full down and hard press on brake pedal for the FULL procedure. Takes a couple of minutes normally.
chrishatred
Thanks!
Do ford dealers have more options the relearn the Powershift?
The result with forscan is different to a „Ford“ relearn.
The powershift reacts different to throttle position.
It feels as if the range is smaller and i get full throttle more early.
NiceMan
- Vehicle: Ford Mondeo ecoboost 203hp 2011
- Contact:
I have 2011 Mondeo whit PS and it drive 105tkm now, i interest this how it works peaple...
I have IDS and it is the same two functions on there for the 6DCT450, Clutch and Gear Fork learn.chrishatred wrote: Fri Aug 23, 2019 10:36 am Thanks!
Not tried calibrating clutches on IDS to see if it has a different outcome to FORScan though.
why clutch learn always stop me clutch boost learn now? half year this go fine... but now stop always same. no fault codes.?
- Screenshot_20191030_184044_com.astech.forscanlite.jpg (446.36 KiB) Viewed 12110 times
and shiftfork learn cant complete too.. but gearbox works good. and not problem. i just want do this learns again. this all learnigs compelet fine half year ago.. and not now.. do i have problem my elm.. i hope not the gearbox
Rivelino
- Vehicle: Mondeo,MK4, 2.0L Duratorq-TDCi (163PS) ,2013
Hi to everyone,
4 days ago i repaired PS on my Mondeo mk4 DCT450.
Full repair including stripped mecatronix and cleaned.
After first start i made a clutch and fork learn.
All was OK.
After 10 km started to kick on D and R when starting from 0 KM.
I try it to make again clutch learn and i have lutch Ventilation Learn - ERR.
Anyone know something about it ?
Now i have P0949 on TCM.
Log from Forscan.
(OK) [19:41:13.245] Clutch System Learn has been started
(WARN) [19:41:23.129] Checking vehicle conditions...
(WARN) [19:42:01.041] Performing function: Clutch Stroke Learn
(OK) [19:42:10.409] Clutch Stroke Learn - OK
(WARN) [19:42:10.431] Performing function: Clutch Ventilation Learn
(ERR) [19:42:36.924] Clutch Ventilation Learn - ERR
(OK) [19:42:54.156] Please wait...20 seconds
(ERR) [19:43:45.732] Service procedure has been interrupted
All was OK.
Log from Forscan.
