ipc module update error
good morning everyone, I tried to update my ipc module, only that during the procedure it got stuck, now I find myself with the instrument panel completely off, I tried to redo the operation, but I can no longer proceed, the last attempt stopped me at 85%. can you help me why I can't finish the operation? thank you sorry I have a Ford cmax 2016
- fordsmax471
Re: ipc module update error
which adapter you are using
whether you are using a battery charger
whether you can connect to the IPC
vehicle previous backup profile
which date FORScan 2.4.0 version you are using
we're a lot of people with the same isue in my19 and my20... IPC module is "untouchable" for now.
Waiting a Forscan update or some other solution for this.
i have an els27 cable, the machine is connected to a charger, the ipc module i see it, but when i try to write the firmware it freezes, the last time at 83%, i am using forscan 2.4 20200120 now, I find myself with the instrument panel completely off
I have updated ipc with forscan 20200121 and obdlink ex
- fordsmax471
I wanted to thank fordsmax471 for the assistance, thanks to him and his experience I was able to restore my IPC module which during the update had crashed. thanks for everything
explain how you solved it, it can be useful to othersalbix76 wrote: Tue Apr 14, 2020 1:36 pm I wanted to thank fordsmax471 for the assistance, thanks to him and his experience I was able to restore my IPC module which during the update had crashed. thanks for everything![]()
- fordsmax471
Yes, suregianni_66 wrote: Tue Apr 14, 2020 2:11 pmexplain how you solved it, it can be useful to othersalbix76 wrote: Tue Apr 14, 2020 1:36 pm I wanted to thank fordsmax471 for the assistance, thanks to him and his experience I was able to restore my IPC module which during the update had crashed. thanks for everything![]()
written by google translation
note
but here he is:
very goodfordsmax471 wrote: Tue Apr 14, 2020 2:17 pmYes, suregianni_66 wrote: Tue Apr 14, 2020 2:11 pmexplain how you solved it, it can be useful to othersalbix76 wrote: Tue Apr 14, 2020 1:36 pm I wanted to thank fordsmax471 for the assistance, thanks to him and his experience I was able to restore my IPC module which during the update had crashed. thanks for everything![]()
if the module update failed![]()
notewho does not use the battery charger and does not make a backup cannot help
but here he is:
we used FORScan software 2.4.0 date 20200114
older car profile ( so we always make backups
the same module software that was originally in the figure no.3
and settings FORCE PROGRAM in the figure no.4
we adjusted the forscan connection settings all auto and automatic baud rate speed
we setup the OBD adapter baud rate 38400bps and FDTi dariver settings latency timer =1
battery charger 6amps
it was 2 days all does not immediately remember![]()
