[SOLVED] Digital IPC Firmware update
Amenra
Vehicle: Mondeo MK5 2.0 TDCi 180ps
Post by Amenra »
Hello everyone.
I have already performed software updates several times with Forscan, always without problems. But now I have a little one. I would have liked to give my IPC a different view, so I changed the BJB file. When testing the firmware, it started with the bootloader, but nothing else happened, so I thought, programming directly. It seemed to start, but immediately I got the message as in the picture. No matter what I tried, no matter what settings I changed, nothing happened. I'm probably overlooking something, so I wanted to ask for some feedback along this way.
I have a OBDLinkEX with the latest firmware. (and Forscan 2.4.5) All other actions work well with it. I did a firmware change to a digital speedo in the middle about a year ago, also no problems with it.
Where should I start looking?
Thanks in advance !
(If I've posted this in the wrong section, my apologies)
(If this question is asked several time, sorry but I didn't find a related question, but it could be my search method :D )
SAMEH2077
Vehicle: Ford Edge 2014 3.5 litter 285 hp
Re: IPC Firmware update won't start (also can't read asbuilt)
Post by SAMEH2077 »
Try to make the update for each file by selecting custom and program each file separately
Amenra
Post by Amenra »
SAMEH2077 wrote: Sat Mar 26, 2022 4:37 pm Try to make the update for each file by selecting custom and program each file separately
I already tried. Always the same. Starts with SBL but immediately stops.
I'm currently running that version.
I will give it another try tomorrow morning and see what happens. :roll:
Amenra
Post by Amenra »
Thanks to fordsmax471 the problem is solved.
Re: [SOLVED] IPC Firmware update won't start (also can't read asbuilt)
ipc update:
first update the original files
SBL (Bootloader): EJ7T-14C025-AA
KS7T-14C026-AJD
KS7T-14C026-BJD
KS7T-14C088-AJD
KS7T-14C088-BJD
or
JS7T-14C026-AJB
JS7T-14C026-BJB
JS7T-14C088-AJB
JS7T-14C088-BJB
second upgrade if we want ipc different colors and icons
ipcmod: KS7T-14C088-BJD
or
ipcmod: JS7T-14C088-BJB
S-Max Logo foto.png (612.5 KiB) Viewed 13515 times
Amenra
Post by Amenra »
Can say that I flashed my IPC to full digital without a problem with Forscan. I've done it 100 times now and never experienced a difficulty. Templates uploading goes quick (5 to 10 min) So everything is working fine.
stimpy88
Vehicle: Ford Mondeo Mk5 - Diesel 2.0, 150, 2017
Post by stimpy88 »
Amenra wrote: Fri May 27, 2022 8:52 am Can say that I flashed my IPC to full digital without a problem with Forscan. I've done it 100 times now and never experienced a difficulty. Templates uploading goes quick (5 to 10 min) So everything is working fine.
Do you mean that you upload your own graphics to the IPC? If so, what do you use to make the graphics?
Amenra
Post by Amenra »
Yes you can upload whatever graphics you want to the IPC. Graphics are made with an online app. Pimp My Ford...
https://pimp-my-ford.web.app/ipc
Basically you prepare your VBF file and flash it to the IPC. Thanks to Szendo (Pimp My Ford app) and Chemikus (German MK5 forum) all this is possible. :mrgreen:
fatcam328
Vehicle: 2017 Continental 3.7, 2019 Expedition 3.5
Post by fatcam328 »
Is this vehicle specific? If not, how would I determine which file correlates with the background? Thank you
OBDLink EX
