Oil Reset
Re: Oil Reset
Yes holding both brake and gas peddles to the floor with key on and motor not running, this procedure works on my 2021 T-350HD AWD DRW.
Re: Oil Reset
2 methods depending on which generation
If IPC has coloured centre screen and has vehicle maintenance, then scroll through to oil life reset and press and hold OK
Ones with turn off ignition , press and hold down brake and accelerator ,turn on ignition to run(not start) and wait 20 seconds or until spanner light flashes and turn off ignition. some models you have to do it twice before it is reset.
