Page 2 of 6
Re: Fiesta MK8 Active park assist retrofit guide
Posted: Tue Jun 14, 2022 10:54 am
by Graham17
Console switch is held in by 2 plastic tabs, if u insert something flat like a thin knife on the left and right sides of switch then lever up it should pop out, connector has locking tab to release. Doubt switch is at fault.
I found when i upgraded HVAC module eco stopped working. Changing back to original sorted it out. So could well be something to do with HVAC module or settings as stated.
Posted: Fri Jul 22, 2022 9:01 am
by franek126
Great instruction, the wife will be delighted! Can you provide me the interior equipment loom number which is factory prepared for park assist? I am wondering about the possibility of translating some part of the wiring harness instead of adding a lot of wires...
Posted: Fri Jul 22, 2022 4:59 pm
by Graham17
Sorry sold Fiesta long time ago now, so cant remember loom codes, but wouldnt help anyway as i added the extra wires myself, however its not as simple as buying a loom for active park assist, it would need to be a full body loom, but also you would need centre console loom with additional wiring for extra switches, rear and front parking looms. The cost would be prohibitive never mind the time to strip out and re fit the looms. Also each loom is geared to the options your car has, so going to Ford and asking for a new loom wouldnt work either, also you have to specify the loom which has all of your current options + active park assist
Trust me! if you cannot make up the looms yourself give it a miss, unless you can find someone who can, it honestly would be cheaper selling your current car and buying one with the active park already fitted.
A lot less hassle too.
Posted: Sat Dec 31, 2022 8:33 pm
by pierogi
hi.
Sorry for my english
I have an escape 2017. I added sensors to the front and activated Active Park Assist.
Everything works. Parking perpendicular and parallel. I only have one problem. There is no sound that should be when he finds a parking space - such a Ding-Dong
I am asking for a hint whether to look for a solution in APIM or PAM.
Thank you for all suggestions.
Does anyone know exactly what to change to get this sound to appear?
(google translate:)
I just want to turn on the sound when a parking space appears (the green tick on the screen) - just like in the picture and a short video
https://youtu.be/7Lo-oLlZkqE
Posted: Sun Jan 01, 2023 7:36 am
by Graham17
Didnt know it did, from recollection cant remember my Fiesta mk8 doing it, or my current Focus mk4, i just watch the on screen prompts.
However if you come up with a solution let us all know.
Posted: Sun Jan 01, 2023 8:18 pm
by pierogi
Hi - I found these sounds
There was too much alcohol yesterday ... instead of "Chime" I searched for "Chimes"
Below is a fragment of the sheet with all the options. I haven't tested it yet - tomorrow I'll let you know what and how
Thanks for the tips
(google translate
Posted: Mon Jan 02, 2023 9:02 pm
by pierogi
Unfortunately... I can't get these sounds to work. I have tried almost all options. plz help
Posted: Mon Jan 02, 2023 9:16 pm
by Ghano38
What are the part numbers of the PAM and the ACM?
Please post in this topic only to concentrate help since it is how to guide.
Posted: Mon Jan 02, 2023 9:23 pm
by pierogi
OK - im sorry
PAM: F1ET-15K866-BH
ACM: GJ5T-19C107-DC
thx
Posted: Mon Jan 02, 2023 10:02 pm
by Ghano38
Try to upload as built for ACM with this VIN 1FMCU0G94HUB21510
and for PAM with this one
WF0VXXGCEVGK07563
From here
https://www.motorcraftservice.com/Home/ ... returnUrl=%
Keep in mind that the PAM comes from a C-Max or Focus mk3.5 according to the part number so you have to make some changes in order to make semi automated parking working according to the Escape/Kuga size.
