Page 2 of 3
Re: 2.4.4 - Cannot read BCMii
Posted: Sun Oct 24, 2021 6:53 pm
by smartguy69
I am going to stick with V2.3.41 for now as it works for me. I never installed V2.3.42.
Looks like @admin need to take a look and see why V2.3.43 and the 2.4.4 have an issue accessing BCM Main Configuration and why the SBL bootloader screen doesn't populate.
Posted: Tue Oct 26, 2021 6:41 am
by cezarg1410
It is well known issue.
I wrote an email to support and They send nie very quickly version 2.4.5 and there it works fine.
Posted: Tue Oct 26, 2021 10:12 pm
by srahul0809
I have the same issue. I am using 2.4.43 release. Is there anyway I can get 2.4.5?
Posted: Thu Oct 28, 2021 9:05 am
by ladadens1
hi! i have ford cmax bcm problem. i read orig bcm some weeks ago.
now i install new (2.3.43) and cant read old or new bcm.so its an big bug in software
it read 5% then shows contact developper.so im not the only one.
have full leicense but can do nothing
Posted: Fri Oct 29, 2021 7:15 am
by ladadens1
would be nice when support can send me to
ladadens1@aol.com
big thx
Posted: Sun Oct 31, 2021 4:00 pm
by djdekl
Hello, I have a ForDiag USB cable adapter + Forscan 2.3.43 + Ford Focus MK3.5 - BCMI primare configuration edit - when started, the process is abort.
Older versions of Forscan 2.3.39 works fine
Please help
Posted: Fri Nov 05, 2021 5:33 pm
by Mark12
Hello guys, I encountered the same issue with FORScan 2.4.4 and after un-installing and re-installing an older version I had the exact same issue present.
What resolved this error for me was;
1. Un-install FORScan.
2. In Windows go to folder options and check the box marked ' Show hidden files, folders and drives '
3. Navigate to on your main drive ' C:\Users\***Your user name here**\AppData\Roaming '
4. You should find a ' FORScan ' folder.
5. Delete this folder or just rename it if you like.
6. Re-install FORScan and you should now be able to read the BCMii with no issues.
Hope this helps someone out.
Posted: Tue Nov 09, 2021 8:27 am
by laurentiu7
Can't access BCM Main Configuration, message "Service procedure interrupted " ,when started, the process is abort.
I have a USB cable adapter + Forscan 2.3.43.Older versions of Forscan 2.3.XX works fine.
It seems it's a known issue.
I wrote an email to support and they send me 2.3.44.test20211107 version until official 2.3.44 release has been issued. Hope it will work, I will test later and came back.
Posted: Mon Nov 15, 2021 8:44 pm
by MduButh
Hi All
Anyone who has finally come right with 2.3.43 issue of BCMii not readable? please share your work around if any.
Posted: Tue Nov 16, 2021 9:18 am
by Takiry
Hello, I also had the problem with version 2.3.43
I wrote to support and they gave me 2.3.44TEST. Here you can read out without any problems. However, there is then another error when writing.
I use an ELM327 HS / MS
As has already been written here several times, it is a ForScan problem. Just use an old version. I tested 2.3.41 and 2.3.39. Both work fine.
