Clear airbag sensor light
Andyfocus
Re: Clear airbag sensor light
Post by Andyfocus »
if it has the 95640 chip then clear
00001000 to 00001610 (incluing both lines ) to f's
this will remove all the crash data then rewrite the chip with the editted bin file if you have the equipment .
if not plenty of tuts online to make a chip reader with it on board , or if you can remove the chip a programmer is only about £3 and and the lead to connect to chip is about £1
so all can be had for less than £5 , some sell complete kits for around £5 .
smswapp
Vehicle: F-150 3.6L Ecoboost 2016
Post by smswapp »
I have a 2017 F-150. I changed the tire size (using easy peesy calculator on this forum). This caused the wrench light to come on. I ended up having to run a PCM reset, which was sucessful....but now the speedometer shows 99 miles per hour when going 45 miles per hour.....and the airbag dash light is on permanently.
What in the Sam Hell did I do?
Any suggestions on how to cure this?
Should I fix the tire size again for the speedometer issue...? And will unplugging the battery for a bit solve the airbag light issue?
I don't want to reset the PCM again....seems that is what may have caused the airbag light to come on and cancel the tire size I input.
HELP Please!
I fixed the tire size on my 2016 F150 and some other items with no issues and no dash lights....did they do something for 2017 F150's? Or did I simply jack something up in playing with the 2017 truck?
smswapp
Post by smswapp »
I am using an "ELMconfig compatible" mad by "ohp" reader with the HS-can and MS-can switch (usb verison).
Where is the chip to remove you mentioned?
Sorry - I am a newbie for sure!
sebastian323
Vehicle: 2011 Ford Fusion AWD 3.0L V6 SEL
Post by sebastian323 »
what about replacing the air bag module with a used one from a car that has not been in a crash and flashing over the AS-built data. is the crash error code stored in the restraints control module (RCM) itself ?
k4rl.w
Vehicle: transit tdi 2.0 2005
Post by k4rl.w »
Following as I need to do this too
matt1980
Vehicle: Ford Ranger, 3.2 diesel, 2016
Post by matt1980 »
Following, I need to do the same on a 2016 wildtrak.
Andyfocus
Post by Andyfocus »
the crash data ( speed ,braking yes/ no ,seatbelt on /off etc ) is all stored in the RCM and this is the data that needs to be removed along with the ipc error.
