Now: that comment about "Moving the wheel left or right to take up slack", I find interesting! Is that slack in the wheel when the system is off as in Engine is not running?ZekeTheSneak wrote: Sat Feb 25, 2023 8:36 pm On the f150 forums it is described as pull drift and wander. There is a Ford investigation on the issue. I forget the official term when Ford is looking into something? I can provide some links to that. But no tsb has been issued as far as I can tell.
https://www.f150forum.com/f118/2015-201 ... er-336159/
The truck will pull slightly to one side and then correct and go the other way and basically wander down the road. It is not an alignment issue but a steering rack programming issue and/or epas issues. The center of the wheel feels dead. I have to move the wheel left or right to take up the slack. I have tried this with the "pull drift compensation" turned on and off multiple times. Multiple alignments. Inspected equipment and tryed replacing lower control arms. Also upgraded to the SPC camber caster adjusters.
Module firmware update, Error opening file
Re: Module firmware update, Error opening file
ZekeTheSneak
- Vehicle: 2016 F150 5.0 V8
When it's off it feels firm.
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
To go back to topic:
You have not loaded the needed Files, thats all.
If you have a paid licence Forscan will load the Files.
With a free trial not.
Best regards
Karsten
Best regards
Karsten
Changed on my 2011 Focus:
Hill Assistant, Auto High Beam, Sync 3 with Navigation, Traffic Sign recognition, Lane Keep Assist,
Lane Centering Aid, Rain Sensor, Ambient & Footwell Light, FL ST-IPC, BLIS, HSW from Focus FL.
