Error on FCDIM after SD Card Nav Update
kevinnn_s
Vehicle: Ford Focus MK3 1.6 Ecoboost 182
Re: Error on FCDIM after SD Card Nav Update
Post by kevinnn_s »
Thank Txusman, this worked for me too, but same as you i still have the FCDIM U2101: 00-2F floating around.
I've looked at the blocks danY2014 uploaded and all are the same for me. I've also did a ECU reset for the FCDIM using FoCCCus, but that didn't help either.
In my case it's also a Focus MK3 from 2011 with BT/Voice, so no sync.
piolin49
Vehicle: Ford B-Max
Post by piolin49 »
Hi again everybody:
I tried 7A5-01-01 10BE and the result was the same as the other chap. One DTC goes bie but remains one of them: U2101:00-2F.
I tried too 7A5-01-01 1ECC (taken from a B-Max with the same FCDIM board) and the result was the same: DTC U2101:00-2F.
Anybody solve the issue?
I guess we have to fit a suitable code in BCM for example…..
Waiting your reply.
Regards
Txusman
Vehicle: Ford focus ecoboost 150
Post by Txusman »
yes, that is what i need, but it is the same i have so it not worked for me.
Thankyou.
