Page 2 of 9
Re: ADD CLIMATE
Posted: Sat Oct 14, 2017 2:31 pm
by gbiker
nothing worked for me 2017 f250 xlt with sync 3 and nav. cant get climate control to come on navigation tried a ton of combos no go.
Re: ADD CLIMATE
Posted: Wed Oct 18, 2017 7:20 am
by Nitemare
Thought I'd just ask again if ANYONE can fix my climate SYNC 3 issue??
CAR: Focus MK3.5 2017 UK MODEL
Added CLIMATE screen to SYNC 3 as per 7D0-01-02 xxxx x3xx xxxx
HOWEVER ... temperature zones shown on SYNC 3 are reversed from the physical hard buttons ... i.e. when adjusting driver temperature hard button then the SYNC 3 screen shows changes on screen to the passenger temperature zone and vice versa!!! :?:
HAS anyone a solution to this issue???
Thanks. :)
Re: ADD CLIMATE
Posted: Sun Oct 29, 2017 5:28 pm
by timmibaer
I have done the same in my 2017 Focus mk3.5 . There's no effect on the Sync 3 Screen. Is there any other sollution for the mk3.5 with Sync 3 .
Regards, Michael
Re: ADD CLIMATE
Posted: Mon Jan 08, 2018 4:10 pm
by metalzone
Livnitup wrote:Try this:
7D0-01-02 xxxx x2xx xxxx
and 1 of the following:
7D0-01-01 xxxx xxx3 xxxx - Dual Zone & HD radio avail
7D0-01-01 xxxx xxx2 xxxx - Dual Zone & HD radio not avail
I tried both in my 2017 Ford Focus EU spec and got a different Nav distance for the same turn etc. On the touch screen it was displayed the correct distance, on the instrument cluster's small screen i got the turn indications with a completely different distance.
First attempt: 7D0-01-02 xxxx x2xx xxxx + 7D0-01-01 xxxx xxx3 xxxx - Dual Zone & HD radio avail
Second Attempt: 7D0-01-02 xxxx x2xx xxxx + 7D0-01-01 xxxx xxx2 xxxx - Dual Zone & HD radio not avail
Regarding the Climate menu, Climate temperature voice control, Knobs and touch screen working great, just got the side effect of distances missmatching, have i missinterpretated the instructions? If not, does anyone knows the right codes?
Re: ADD CLIMATE
Posted: Wed Jan 17, 2018 9:17 pm
by metalzone
Thanks to murat_kavuk, i got climate working on touch screen, without any negative side effect. These were the instructions:
7D0-01-02: xxxx x3xxx xxxx - Climate button + climate voice control
7D0-04-01: xxxx xxx0 xxxx - To see set temperatures on main screen (shortcut to climate setting window is climate button enabled)
Re: ADD CLIMATE
Posted: Thu Jan 18, 2018 7:57 pm
by Cosmicbase
metalzone wrote:Thanks to murat_kavuk, i got climate working on touch screen, without any negative side effect. These were the instructions:
I have a Ford Focus 2017 facelift 1.5l Tdci with sync3
Which module do I have to take in Forscan?
APIM???
Re: ADD CLIMATE
Posted: Thu Jan 18, 2018 10:49 pm
by metalzone
APIM???
Yes it is, just change whatever value you have to the number in that specific position and you will have climate control working on the touch screen + temperature voice control. I have attached a print of my Apim module before the changes and marked the values that have to be changed. Tell me If you need any additional help.
Re: ADD CLIMATE
Posted: Fri Jan 19, 2018 7:14 am
by Cosmicbase
OK thanks a lot. I will try it and give you a response.
Re: ADD CLIMATE
Posted: Fri Jan 19, 2018 7:18 am
by Cosmicbase
APIM???
I have dual zone Climatic. You too
Re: ADD CLIMATE
Posted: Fri Jan 19, 2018 11:12 am
by metalzone
I have dual zone Climatic. You too[/quote]
Yes, I do.
