Page 2 of 5
Re: P1635 in TCM or PCM after tire size change
Posted: Fri Jun 28, 2019 1:47 am
by josephj22
I have the 2018 ford ranger wildtrak with 3.2L diesel engine, yesterday I tried to update the hex value of my tire size as below:
- Original size 265/60R18 BCM value 934
- New tire size 285/70R17 updated BCM value 9DE
Result P1635, cannot clear even after attempting PCM relearn.
Then I followed the advise here and checked the live ID of tiresize Rev/mile and found the following:
- on original tire size: 683 Rev/mile equivalent to 30.5" tire
- on updated tire size with p1635 code tire size live value: 664 Rev/mile, which means that this is the minimum acceptable Rev/mile for TCM.
I changed again the BCM value to 977 which is equivalent to a tire size of 31.5" to match with 664 Rev/mile now p1635 code cleared.
Road test results:
- on original tires cruise control set at 117Km/h GPS speed 113Km/h
- on new tires (32.7") without BCM update: 110Km/h cruise control, GPS speed 113Km/h
- on new tires with BCM value updated to maximum allowable tire size (minimum allowable rev/mile of 664 for 31.5" tire) now cruise control and GPS speed are exact match and sometimes only 1Km/h difference at higher speeds.
Now I left out wondering what strategy the manufacturer uses to calculate speed and odometer reading? If on original settings and tires, the speedometer was not accurate, and now with upgraded tire size and updated BCM tire size for a smaller tire then actual speedometer is accurate. Does that mean that from factory they keep on purpose speedometer readings higher than GPS? And if this is the case what about odometer readings?
Posted: Sat Aug 31, 2019 4:18 pm
by ramky27
josephj22 wrote: Fri Jun 28, 2019 1:47 am
Thank you so much. Your post above helped me no end.
I have the 2016 3.2 Ford Endeavour (in India, the Everest is called by that name due to trade mark issues). I gave her brand new shoes upsized from 265/60/R18 to 285/60/R18.
When I tried changing the hexadecimal value for tyre circumference from 0934 to 097E, it threw the same error code. I followed the exact same procedure you mentioned and corrected the value to read 0977 which equates to the minimum allowable revs/mile on my car too (664). Now all error codes are clear and I am satisfied the tyre size has been updated.
Yet to compare the GPS speeds though. Thanks once again guys and to FORSCAN. You saved my day.
Posted: Fri Oct 18, 2019 3:31 am
by kingshado
I’m trying to get this to work on my 2017 f250 6.7
I’m confused we’re the revs per mile are being changed. I changed the hex in bcm for the size so how do I keep the size with out getting the out of range dtc. This is for 37x12.5x20 tires. The Speedo is correct now but check engine with out of range code.
Posted: Fri Oct 25, 2019 7:07 pm
by captainsdc
I wonder if this is where I may have to go with my 2013 F150 with the 3.73 trans and new 275/65-20 K02 tires (stock were 275/55-20).
Ramky27, where did you find the min allowable revs/mi (tire size) per your transmission?
My GPS gets off if I drive long enough so I know the tire size change is what did it.
Scott
ramky27 wrote: Sat Aug 31, 2019 4:18 pm
Posted: Sat Nov 16, 2019 9:47 pm
by wreedsvt
kingshado wrote: Fri Oct 18, 2019 3:31 am
Did you ever get this figured out? I am trying to do the exact same thing to a 19 F250.
Posted: Mon Nov 18, 2019 6:44 pm
by captainsdc
not me, yet. i'm still hoping someone will share...
Posted: Wed Nov 20, 2019 6:32 am
by kingshado
wreedsvt wrote: Sat Nov 16, 2019 9:47 pm
Nope I’m just still driving around with the check engine light on ugh. Seems like the 2 above that said they got something to work no longer follow the post.
Posted: Thu Nov 21, 2019 9:12 pm
by captainsdc
I'm bookmarked and subscribed but still don't get the usual notices...
Posted: Thu Nov 21, 2019 10:21 pm
by gravedgr
Also hoping someone figures out the revs number needed. I have 37” tires too and because the CE light is always on I worry about missing a warning for something legit.
Posted: Fri Nov 22, 2019 6:45 am
by kingshado
I feel the same way about the cel being on and missing something cause of it. Hopefully someone will chime in.
