Ldsundance wrote: Sun Jul 07, 2019 2:03 pm
how did you resolve the chimes issue?
Depending to your PDC system there are suitable as-built configurations in both APIM and ACM.
As, Mark already told, focus mk3 (pre-lift) uses C1MCA Architecture while face-lift focus M(k3.5) uses the CGEA 1.3. Same applies to C-Max and Kuga pre-lift and facelift versions.
Mark12 wrote: Fri Mar 22, 2019 7:53 pm
Just wanted to post that I got the park graphic to display on Sync II and also an aftermarket camera with the park graphic in the corner to display when in reverse, this might be helpful to anyone doing a Sync I - I.I to Sync II conversion on a Mk3 Focus or is interested in doing it.
Installing a facelift Mk3.5 PAM Module is not required - if you can change the PDC Architecture type in the Sync II APIM
Focus Mk3 is a C1MCA Architecture car - If your Sync II donor car was a Focus Mk3.5 the Architecture would be set to CGEA 1.3
Sync II APIM;
PDC HMI: Set to ON
PDC Architecture: Set to C1MCA
Transmission Type: Set to Manual or Automatic (whatever you have)
Parking Assistance: Set Rear, or Front Rear, or Front Rear with SAPP (whatever option you have installed)
Vehicle Style: Set your body type (hatchback, estate. etc) this will reflect what park graphic is displayed
I researched many as-built coding but could not find the correct bits to make this work so I used UCDS to set these options
So there is no solution via Forscan? Are you able to explain step-by-step solution? I would really appreciate it.
I've just fitted reverse camera to my 2018 kuga, (sync 3) I'm wondering of the process is the same for sync 2?? I have the graphic from.the parking sensors at the rear but would really like the park graphic lines too, if this can be done with forscan I'd love to know how, many thanks in advance
