Francuzzz
Vehicle: Mitsubishi Pajero,бензин 3.8/225, 2004
Post by Francuzzz »
Hello! Ford F150 2021 year Hybrid
Master key lost. Mykey activated. Tried to disable it from ipc, but it only disable warning messages, but it still activated. Tried different methods from this topic, but nothing helps. May be some one tried to do it without FDRS online with FORD F150 2021? What can help else?
Francuzzz
Post by Francuzzz »
Did it only with ford online FDRS
IdaTex2016
Vehicle: F-150, 2.7L Ecoboost, 2017
Post by IdaTex2016 »
So I've seen someone post up that they have a 2017 (as do I) and were not able to disable either mykey or the speed limiter. I've tried 3 different adapters and none have worked. Yes I did purchase the extended license. Also I don't have the Admin or programming key. Does anyone know how to do this without having to pay the dealer $300-$400 for a new programming key?
bigtomi
Vehicle: ford kugamk2
Post by bigtomi »
I have two Kuga mk2 remotes how do I recognize which remote is the administrator
Stealthrider98
Vehicle: Expedition, Ecoboost 3.5L/365 hp, 2016
Post by Stealthrider98 »
FORScan wrote: Tue Dec 17, 2019 7:43 am It is typical situation when people have MyKey enabled and have no Admin key that would allow to clear MyKey feature. Previously, our support answered that there are 2 ways to do it with FORScan:
1. Reprogram PATS - erase all known keys and program 2 new ones. This removes MyKey completely, but it is quite "heavy" way: it requires 2 working different good quality keys and PATS programming functions (in FORScan it is available not for all models).
2. Disable MyKey options in IPC and other modules if available. This removes chimes and warnings, but not MyKey itself. Some limits, like speed limit, may remain active after this procedure.
But one of our users found a workaround about how to clear MyKeys with FORScan but without any programming. It can be done in FORScan for Windows or FORScan Lite for iOS, Android. Here is the exact sequence:
1. Start the car and connect to it with FORScan.
2 Start PCM KOER test (Tests->PCM Key On Engine Running On Demand Self Test)
3. Wait until the test is completed
4. Remove keyfob from the car in case of keyless system (with engine start button). In case of standard blade key, you have to block the transponder (for example, wrap the keyfob with a foil).
5. Stop the engine (turn the ignition off)
6. Turn the igfnition On but don't run the engine.
7. Go to MyKey menu in your instrument cluster and execute Clear MyKeys option .
You now have MyKey removed.
Note: this was tested on cars with gasoline engine, not tested on diesel engines.
Please leave your feedback on this method.
My car is a 2016 Ford Expedition with push button start and remote start. I have tried this several times, and it does not work for me. I have the latest FORScan with an Extended License. The problem I have is with step 7. When I go to Settings-Advanced Settings there is no MyKey option. The only way to get the MyKey option after steps 1 through 6 is to have the key in the car. Problem with that is MyKey is activated when the key is in the car. Has anyone experienced this when clearing MyKey? What did you do to get the MyKey option in Advanced Settings after step 6?
ACAMS
Vehicle: 2014 F350 SRW Platinum 6.7 diesel
Post by ACAMS »
I have this same problem with my 2014 F350
alin.milan
Vehicle: Mondeo, 1.6 TDCI, 2011
Post by alin.milan »
For Bmax, 2015 Diesel, work very simple:
IPC>Central Configuration (Main){Engineering 1} > MyKey: put it on disable> write
that`s all!
cr3pt
Vehicle: B-MAX,1.0 125, 2015
Post by cr3pt »
Clean in Ford B-Max 2015 gasoline don't work...
(PCM KOER test (Tests->PCM Key On Engine Running On Demand Self Test is interupted)
Any other sugesstion?
regards
Marcin
igasanti
Vehicle: Ford Edge V6 3.5, 2013
Post by igasanti »
Probably the problem has not been solved. After running the KOER test the menu item does not appear.
I solved the problem only by disabling MYKEY from IPC
igasanti
Post by igasanti »
igasanti wrote: Wed Dec 20, 2023 5:17 am Probably the problem has not been solved. After running the KOER test the menu item does not appear.
Upd
After disable MyKey in the IpC module, the notifications on the dashboard are gone, but the speed and music limits still exist. The car has keyless access, I tried to start the remote key, but when I try to enter the menu, the Mykey system reports that the key is not in the car.
Do you have any ideas?
