Where to buy a compatible adapter?
radiobrown
Vehicle: 2014 cmax energi
Re: Where to buy a compatible adapter?
Post by radiobrown »
IndustrialDon wrote: Sun Feb 18, 2018 10:35 pm Found this one on Amazon for $29.99, received it today, and it worked perfectly on my 2015 F-150 Platinum:
OHP Ford ELMconfig USB device 500kbit/s ELM327 compatible interface with MS-CAN switch for Forscan FoCCCus Mazda OBD2 diagnostics
Keep in mind that you DO need the extended license.
Also, if you've already created a profile for your vehicle and said you don't have "a switch" on the adapter, delete the profile and create a new one.
any reason you didn't use this one?
https://www.amazon.com/gp/product/B06XJ ... LA1C&psc=1
i want to be able to use my touqe pro app while i drive as well on the phone... so not sure whats the best thing to get.
any one have a idea of what i should get that can be used on the computer and the phone for other apps than this?
Alen
Vehicle: Mondeo, 2.0 tdci, 96kW, 2007
Post by Alen »
forduser
Vehicle: fusion,1.5L,2014
Post by forduser »
ozon8r wrote: Thu Sep 27, 2018 3:23 am This one worked on my 2018 F250 from Amazon for US$19, https://www.amazon.com/gp/product/B01N1 ... UTF8&psc=1.
I can confirm that this tool works fine on a 2014 Fusion.
chrisw
Vehicle: 2013 Ford Fiesta ST180 1.6
Post by chrisw »
I bought this adapter recently to cycle the ABS pump on my Mk. 7 (MY16) Fiesta ST and it worked perfectly. Described on Amazon as "Dailyinshop ELS27 FORScan OBD2 USB Scanner".
Shopped around quite a lot to find a convincing looking adapter which was described as using an STN1170 chipset.
YMMV of course but the adapter I received works fine for this usage :) Seems it is a Viaken STN1170 chipset inside (or at least a compatible clone).
When I read the CANBUS I see a handful of minor DTCs, some of which I suspect may be incorrect interpretations. The car passed its service and MOT recently at a main dealer and the garage did not remark about any unacknowledged DTCs or ECU issues so I'm happy. I also have a slightly unusual immobiliser on the car which may be causing one or two of these as false positives. I don't know enough about how it's coded to interact with the ECU to know for sure.
Hello world...
breuerm
Vehicle: Ford S-max (WA6), 2.2TDCi/147kW, 2011
Post by breuerm »
forduser wrote: Sat Dec 29, 2018 8:20 pm
It did only partially work with my Smax 8566AXD from 2011. With forscan 2.19 extended license for Windows 7, it could not find the service to set the electronic brake into service mode.
spektr
Vehicle: mazda 6 2.2
Post by spektr »
latest update of forscan lite cost me of sucessfull connection with my elm327 bt adapter. Until now, everything was ok, today after the update, it says that i have a bad clone.
So, my existing elm adapter is 1.5 version, will 2.1 version work with new version of forscan lite?
bitxan
Vehicle: Ford Mondeo 2.0 tdci 140cv 2009
Post by bitxan »
the same thing happens to me, until now it worked correctly
Narly1
Vehicle: F150 STX 3.7L 2013
Post by Narly1 »
So for the meantime why not roll back Forscan to the version that did work?
spektr
Post by spektr »
Yes, I did that. It works ok with previous version. But the question is, will forscan team somehow solve this or not? :)
Narly1
Post by Narly1 »
spektr wrote: Tue Jan 08, 2019 8:11 am Yes, I did that. It works ok with previous version. But the question is, will forscan team somehow solve this or not? :)
Looking at the update history under "What's New" at https://forscan.org/ it's obvious that the Forscan development team is very active. Pretty amazing considering all of this work is FREE.
Either be patient and wait or go buy a commercial product if you can't wait.....
