Ford As Built Data Deciphering
ClockWorK
Vehicle: 2015 Taurus SHO pp
Re: Ford As Built Data Deciphering
Post by ClockWorK »
The AsBuilt Compare tool is not designed to handle CCC (Central Configuration) vehicles.
anarchyx34
Vehicle: 2016 Ford Fiesta SE Ecoboost
Post by anarchyx34 »
Lol i guess I should have read more carefully. That makes sense now.
jonm61
Vehicle: Explorer, 3.5L TiVCT, 2013
Post by jonm61 »
ClockWorK wrote:This will take a little time. I'll probably need to grab between 50 and 100 Explorer and PIU VINs.
You may have to flip more than one bit. In my Taurus, it's 720-01-02, bits 30 and 31 I believe.
If there's anything I can do to help, let me know.
Tank
Vehicle: 2016 Ford Mustang GT350 - 5.2 Ti-VCT, 526 hp
Post by Tank »
ClockWork,
Thanks for the comparison program and upgrades. Good stuff!!!
A little background. I've been attempting to decipher the differences between two 2016 GT350s - one with a OEM differential cooler and pump installed (this offers automatic operation and cycling of a remote cooler pump and temperature display on the dash) and another that does not. The end goal is an OEM functioning diff pump and cooler install in the GT350 that did not come w the diff cooler/pump installed. We've figured out the diff temperature display on the dash but figuring out the operation of the pump is problematic.
I've plugged my VIN (no cooler and pump) and another VIN (w cooler/pump) in your comparison tool and am able to compare as built data. I got stuck at the Deducer- get data. I was able to enter the two VINs to get the .ab saved to the Deducer folder, and html data saved. I then attempted to go to either of the other Deducer tabs. No vehicles are listed and when I hit "Load Stored Data" the program becomes non responsive. I checked the Deducer folder and see that the three files for each VIN are saved from the 'get data' process. There's also a long list of other VIN data in this folder.
I am using a Dell N5010 laptop running Windows 10 home. Using Chrome as a browser. Any thoughts?
Thanks again for the program!!
Kingsammy
Vehicle: Galaxy, Duratorq-Turbo Diesel 2.0 L/182 kW, 2015
Post by Kingsammy »
Tank wrote:I've plugged my VIN (no cooler and pump) and another VIN (w cooler/pump) in your comparison tool and am able to compare as built data. I got stuck at the Deducer- get data. I was able to enter the two VINs to get the .ab saved to the Deducer folder, and html data saved. I then attempted to go to either of the other Deducer tabs. No vehicles are listed and when I hit "Load Stored Data" the program becomes non responsive. I checked the Deducer folder and see that the three files for each VIN are saved from the 'get data' process. There's also a long list of other VIN data in this folder.
This is because the "As-built Explorer" Tool cannot handle the new page which is stored in a html file any more.
For correct working you have to edit the html file which won't work. Change the following part in your saved html-file:
Code: Select all
<ul class="dropdown-menu">
        <li>
                <a href="/quickguides/bodyrepair">Body Repair Manauls</a>
        </li>
        <li>
                <a href="/freeresources/obd">OBDII Theory & Operation</a>
        </li>
        <li>
                <a href="/ownerinformation">Owner Information</a>
       </li>
        <li>
                <a href="/instructionsheets">Instruction Sheets</a>
        </li>
        <li>
                <a href="/freeresources/papercd">Paper/CD Manuals</a>
        </li>
        <li>
                <a href="/quickguides/quickguides">Quick Guides</a>
        </li>
        <li>
                <a href="/freeresources/tools">Tools & Equipment</a>
        </li>
</ul>
    </li>
to
Code: Select all
        <li>
        </li>
        <li>
        </li>
        <li>
        </li>
        <li>
        </li>
        <li>
        </li>
        <li>
        </li>
</ul>
    </li>
The Author of the Tool has to change the routine of the program.
ClockWorK
Post by ClockWorK »
Exactly. New HTML format gets my program stuck in a loop. Just need a little time to look into fixing it and testing it.
ClockWorK
Post by ClockWorK »
Tank
Post by Tank »
Kingsammy & Clockwork,
Thanks for your feedback and effort. I will try again tonight and post what I come up with!
Thanks again!
Kingsammy
Post by Kingsammy »
@ ClockWorK: Great job so far. Your "As-built Compare" Tool works. And thank you very much for the AsBuilt Browser.
Nice to know in your Tool would be an additional listing for each module (ECU) to its corresponding adress in the "Compare AS-Built" tab of your Tool.
Module Adress 720 = IPC Instrument Panel Control Module
Module Adress 747 = FCIM Front Controls Interface Module
and so on.
Here is my list:
  • Name Short Adress
    (Audio) Digital Signal Processing Module (DSP) DSP 783
    4 Wheel Steering (WS4) WS4
    4X4 Control Module (4X4M) 4X4M 761
    Accessory Protocol Interface Module (APIM) APIM 7D0
    Adaptive Front Lighting System (AFS) AFS
    Adaptive Front Lighting System / Auto Leveling Module (AFS/ALM) AFS/ALM
    Air Conditioning (AC) AC
    Air Conditioning Control Module (ACCM) ACCM 7E7
    Air Suspension (4WAS) 4WAS 020
    All Terrain Control Module (ATCM) ATCM
    All Wheel Drive Module (AWD) AWD
    Alternative Fuel Control Module (AFCM) AFCM 7E5
    Amplifier Module (AM) AM
    Anti-Lock Brake / Traction Control Module (ABS) ABS 760
    Anti-Lock Brake / Traction Control Module (ESOF) ESOF
    A-STOP System (No Idling System) (A-STOP) A-STOP
    Audio Control Module (ACM) ACM 727
    Audio Control Unit (ACU) ACU
    Audio Interface Module (AIM) AIM
    Audio Rear Control Unit (RCU) RCU 774
    Auto Leveling Module (ALM) ALM
    Automatic Ride Control (ARC) ARC 020 ?
    Auxiliary Heater Control Module (AHCM) AHCM 7E3
    Battery Charger Control Module (BCCM) BCCM
    Battery Control Module (BCM) BCM 726
    Battery Control Module (OBD_BCM) OBD_BCM
    Battery Energy Control Module (BECM) BECM 7E7
    Blind Spot Monitoring (Left) (BSML) BSML
    Blind Spot Monitoring (Right) (BSMR) BSMR
    Bluetooth Phone Module (BPM) BPM
    Body Control Module (BCMii) BCMii 726
    Body Control Module / Generic Electronic Module (BCM/GEM) BCM/GEM 726
    Body Control Module B (BCMB) BCMB 7B7
    Body Electronic Module (BEM) BEM
    Camera Module Rear (CMR) CMR
    Cellular Phone Module (CPM) CPM 090
    Central Timer Module (CTM) CTM 052
    Circuit Deactivation Ignition Module (CDIM) CDIM 7E2
    Column Lock Module (CLM) CLM
    Compact Disc Player (CDP) CDP
    Connectivity Master Unit (CMU) CMU
    Convergence Telematics Module (CTMii) CTMii
    Cruise Control (CCM) CCM 764
    Cruise-Control Module (CCM) CCM
    DC to DC Converter Control Module (DCDC) DCDC 746
    Deployable Hood System (DHS) DHS
    Digital Audio Broadcast Module (DABM) DABM
    Digital Audio Control Module C (DACMC) DACMC 7D5 ?
    Driver Door Control Unit (DFDM) DFDM
    Driver/Dual Climate-Control Seat Module (DCSM) DCSM 776
    Drivers Door Module (DDM) DDM 740
    Driver's Seat Module (DSM) DSM 744
    Electric Parking Brake (EPB) EPB 02A
    Electronic Automatic Temperature Control (EATC) EATC 098
    Electronic Crash Sensor (ECS) ECS 058
    Electronic-Controlled Power Steering (EPS) EPS 730
    Energy Management Module (EMM) EMM
    Fire Suppression System Module (FSSM) FSSM 059
    Folding Top Control Module (FTCM) FTCM
    Forward Sensing Camera (FSC) FSC
    Front Body Control Module (F_BCM) F_BCM
    Front Control/Display Interface Module (FCDIM) FCDIM 7A5
    Front Controls Interface Module (FCIM) FCIM 7A7
    Front Display Interface Module (FDIM) FDIM 7A6
    Front Distance Sensing Module (FDSM) FDSM
    Front Electronic Module (FEM) FEM 052
    Front Lighting Control Module (FLM) FLM
    Fuel Additive Control Module (FACM) FACM
    Fuel Fired Coolant Heating Module (FFH) FFH 00F
    Fuel Indication Module (FIM) FIM 016
    Fuel Injection Control Module (FICM) FICM 7E6
    Fuel Injection Control Module (OBD_FICM) OBD_FICM 7E5
    Fuel Injection Pump (FIP) FIP 016
    Fuel Operated Heater (FOH) FOH 00F
    Gateway Module A (GWM) GWM 716
    Gear Shift Module (GSM) GSM
    Generic Display Module (GDM) GDM
    Generic Electronic Module (GEM) GEM 052
    Generic Electronic Module / Smart Junction Box (GEM/SJB) GEM/SJB 052
    Generic Function Module (GFM) GFM
    Global Positioning System Module (GPSM) GPSM 701
    Head Up Display (HUD) HUD 7B2
    Headlamp Control Module (HCM) HCM 734
    Headlamp Control Module 2(B) (HCM2) HCM2 7C3
    Headlamp Leveling Module (HD_LVL) HD_LVL 071
    Heated Steering Wheel Module (HSWM) HSWM 714
    Heated Steering Wheel Module (HV) HV
    Heating Ventilation Air Conditioning (HVAC) HVAC 733
    HVAC Integrated Module (HIM) HIM
    Hybrid Electronic Cluster (HEC) HEC 060
    Image Processing Module A (IPMA) IPMA 706
    Image Processing Module B (IPMB) IPMB 7B1
    Information Center Module (ICM) ICM
    Injector Control Unit (ICU) ICU 016
    Instrument Cluster (IC) IC 060
    Instrument cluster (INST) INST
    Instrument Panel Control Module (IPC) IPC 720
    Integrated Air Bag Module (IABM) IABM 058
    Intelligent Cruise Control Module (ICCM) ICCM
    Intelligent Power Distribution Module (IPDM) IPDM
    Interior Lighting Control Module (ILCM) ILCM 7B5
    Left High Intensity Discharge Lamp (LHID) LHID
    Left Power Sliding Door Module (LPSDM) LPSDM 0B0
    Liftgate / Trunk Module (LTM) LTM 775
    Lighting Control Module (LCM) LCM 070
    Message Center (MC) MC 061
    Motor Pretensioner Module (MPM) MPM
    Multifunction Steering Wheel (MFSW) MFSW
    Multi-Information Display (MID) MID
    Navigation Controller (NAV) NAV 068
    Next Generation Speed Control Module (NGSC) NGSC 013
    Occupant Classification System Module (OCS) OCS 765
    Overhead Trip Computer (OTC) OTC 061
    Park Brake Control Module (PBM) PBM
    Parking Aid Module (PAM) PAM 736
    Passenger Climate-Control Seat Module (PCSM) PCSM 730
    Passenger Climate-Control Seat Module 2 (rear) (PCSM2) PCSM2 777
    Passenger Front Seat Module (PSM) PSM 0A6
    Passengers Door Control Unit (PDM) PDM 741
    Passive Anti-Theft System (PATS) PATS 0C0
    Power Running Board (PRB) PRB 766
    Power Steering Control Module (PSCM) PSCM 242
    Powertrain Control Module (PCM) PCM 7E0
    Rader Brake Support (EBS) EBS
    Rear Air Suspension Module (RASM) RASM 020
    Rear Air Temperature Control (RATC) RATC 099
    Rear Audio Control Module (RACM) RACM
    Rear Body Control Module (R_BCM) R_BCM
    Rear Electronic Module (REM) REM 050
    Rear Gate/Trunk Module (RGTM) RGTM
    Rear Heating Ventilation Air Conditioning (RHVAC) RHVAC 785
    Rear Left Door Control Unit (DRDM) DRDM
    Rear Lighting Control Module A (RLCMA) RLCMA
    Rear Right Door Control Unit (PRDM) PRDM
    Rear Seat Entertainment Module (RETM) RETM 771
    Rear Vehicle Monitoring (RVM) RVM
    Reductant Control Module (DCU) DCU
    Remote Anti-Theft / Personality Module (RAP) RAP 048
    Remote Climate Control (RCC) RCC 098
    Remote Emergency Satellite Cellular Unit Module (RESCU) RESCU 091
    Remote Function Actuator (RFA) RFA 731
    Remote Keyless Entry (RKE) RKE
    Restraint Control Module (RCM) RCM 737
    Retractable Hard Top (RHT) RHT
    Right High Intensity Discharge Lamp (RHID) RHID
    Right Power Sliding Door Module (RPSDM) RPSDM 0B1
    Satellite Digital Audio Receiver System (SDARS) SDARS 782
    Seat Control Module E (SCME) SCME
    Seat Control Module G (SCMG) SCMG 712
    Seat Control Module H (SCMH) SCMH 713
    Secondary OBD Control Module A (SOBDM) SOBDM
    Secondary OBD Control Module C (SOBDMC) SOBDMC
    Security module (CSM) CSM 0C1
    Selective Catalytic Reduction (SCR) SCR
    Side Obstacle Detection Control Module - Left (SODL) SODL 7C4
    Side Obstacle Detection Control Module - Right (SODR) SODR 7C6
    Smart Brake Support/Mazda Radar Cruise Control (SBS/MRCC) SBS/MRCC
    Smart City Brake Support (ICA) ICA
    Smart Start Unit (SSU) SSU
    Speech Recognition Module (SRM) SRM 772
    Steering Angle Sensor Module (SASM) SASM 797
    Steering Column Control Module (SCCM) SCCM 724
    Steering Column Locking Module (SCLM) SCLM 0C3
    Steering Column/Instrument Panel/Lighting (SCIL) SCIL 070
    Steering Effort Control Module (SECM) SECM 7C5
    Supplemental Restraint System (SRS) SRS
    Telematic Control Unit Module (TCU) TCU
    Tire Pressure Monitor (RTM) RTM 751 ?
    Tire Pressure Monitor (TPM) TPM 751 ?
    Tracking and Blocking Module (TBM) TBM 0CE
    Trailer Brake Control Module (TBC) TBC 757
    Trailer Module (TRM) TRM 791
    Transfer Case Control Module (TCCM) TCCM 761
    Transmission Control Module (TCM) TCM 7E1
    Transmission Range Control Module (TRCM) TRCM
    Variable Assist Power Steering (VAPS) VAPS 030
    Vehicle Dynamics Module (VDM) VDM 721
    Vehicle Emergency Messaging System (VEMS) VEMS 091
    Vehicle Security Module (VSM) VSM 755
    Virtual Image Cluster (VIC) VIC 060
ClockWorK
Post by ClockWorK »
You mean like this? If so, download again. And thanks for the list.
