FORScan release notes
soundguy213
- Vehicle: 2015 F-350 Platinum 6.7 diesel
Re: FORScan release notes
I had that already turned off. I'm still stumped.
Soundguy - if you have Windows 10 PRO and a recent CPU, install Windows Sandbox from optional components, set it up by making a sandbox-settings.wsb file with one shared folder (google it), copy Forscan setup to that folder, run Sandbox, install and run Forscan there. If all succeeded, then your antivirus is still active, or you haven't reinstalled Forscan after disabling antivirus.
grant4514b
- Vehicle: F-350, diesel 6.7, 2017
2022 F-350 “Unable to identify vehicle”. Not supported yet? If that’s the case, what’s the timeframe for it to be available?
mwierowski
- Vehicle: F-350, 6.7L, 2022
I am also looking for an ETA as to when FORScan will support 2022 Super Duty trucks?
oldharleyguy
- Vehicle: 2019 F150 Lariat v8 502a Tow package
I too, find this frustrating. I have no idea what values are needed in the ,point an d clck, version, but I do know what hexidecimal values to change. Is there some setting I am missing to enable the old Hex style change methoc?jdaird wrote: Thu Jan 02, 2020 2:03 pm With the latest version of Forscan is the manipulation of the hexadecimal code gone now? Is it all just point and click now?
If so, is there a list of what can be found under which modules?
2017 F-350
TIA
OLDHARLEYGUY
2019 F150 Lariat 502a package
5.0 V-8
5.0 V-8
Service procedure interrupted whenever I click on BCM(Main), all other modules are working fine. Tried 2 different Elm327 adapters on my ford focus 2013 se. same result. Anybody knows how to resolve this?
smartguy69
- Vehicle: Kuga Titanium,2 litre diesel, 150PS, 2015
You need to download V2.3.41 for BCM main central config to work.ad33b wrote: Sat Nov 20, 2021 6:10 am Service procedure interrupted whenever I click on BCM(Main), all other modules are working fine. Tried 2 different Elm327 adapters on my ford focus 2013 se. same result. Anybody knows how to resolve this?
https://forscan.org/download/FORScanSet ... 1.beta.exe
teosorin
- Vehicle: Kuga Vignale 2020, 2.0L Diesel, 140 kW / Mustang Mach-e AWD
Hello, i have 2 questions:
1) I have the FORScan for Windows v2.3.65. i tried to acces my module 'IPMA as_built' and i can't.
Procedure starts and after few seconds (27% loaded)I have this message: Service procedure has ben interrupted.
2) How can i upload the original data (if is necessary) from internet? (My mistake i didn't make file save before changed the modules).
My car is Mustang Mach-e AWD 2023
Thank you!
Thank you!
soaring-sky
- Vehicle: PIU/Explorer, 3.7LNA, 2018
Replying to a random unrelated old thread is not the proper way to get your questions answered on an online forum. Please search if a more suitable thread already exists. If you cannot find any, start a new thread for each question in the appropriate sub-forum.teosorin wrote: Mon Mar 31, 2025 2:05 pm Hello, i have 2 questions:
Thank you!
Team Forscan,
After doing a TCM firmware update on my Ford Focus 2014 should I relearn my vehicale?
