I have Mondeo TDCI 2016 with Sync3. And ECU firmware version in november 2020.
Somebody knows where to find the hex code for the oil life in the IPC?
Cause on a diesel u have the option in the display, but no percentage
How Can I activate the oil percentage?
http://keptarhely.eu/view.php?file=2022 ... ekd3t.jpeg
mondeo mk5 other features asbuilt
Dragunov
- Vehicle: Ford Mondeo MK5 Titanium 2.0TDCi 150HP
Re: mondeo mk5 other features asbuilt
Install latest firmware on your IPC
I have installed the latest firmware to IPC modul already:
http://www.kepfeltoltes.eu/images/2022/ ... _modul.jpg
http://www.kepfeltoltes.eu/images/2022/ ... GS7T_1.jpg
Do you know where can I download the following files?ktibor69 wrote: Fri Apr 08, 2022 6:34 am I have installed the latest firmware to IPC modul already:
JS7T-14C026-AJB
JS7T-14C026-BJB
JS7T-14C088-AJB and JS7T-14C088-AJB.NoMask.vbf
JS7T-14C088-BJB
Köszi
All Those Files except the "NoMAsk" were available at https://www.motorcraftservice.com/! I found them using The Diagnostic Tool Support tab and the IDS Overview link on the Canadian Country site! FORScan is also using a similar URL from within the 2.4.x version to download these files but may not be able to access it from within your country!micaufo wrote: Thu Apr 20, 2023 9:25 amDo you know where can I download the following files?ktibor69 wrote: Fri Apr 08, 2022 6:34 am I have installed the latest firmware to IPC modul already:
JS7T-14C026-AJB
JS7T-14C026-BJB
JS7T-14C088-BJB
Köszi
Your Country list may be different however depending on whether your IP address from your Country would be allowed to access the site in any other country and on the Right to repair laws in your country! I discovered a few weeks back that the UK Motorcraft site, as an example, does not have these tabs in order to access the Calibration files directly!
Hello, I also have a problem, my car doesn't open from the remote control or if I put my hand on the handle and even if I open it manually with the key I can't start it, it's as if I don't have the key everything is black and the steering wheel cannot be heard to unlock, the mirrors do not open and after about 5 minutes it comes back to normal. I want to mention that I changed the remote control battery and the 12v battery with a new one.
Many thanks
Many thanks
Recheck your battery connections and charge state. This sounds very much like a 12V+ power loss since it is affecting just about everything! Easy to check Battery and System voltage first before the more complicated systems of which most shut down( Screens Go black) when battery voltage falls below 11V+ioan pop wrote: Tue Jul 04, 2023 10:41 am Hello, I also have a problem, my car doesn't open from the remote control or if I put my hand on the handle and even if I open it manually with the key I can't start it, it's as if I don't have the key everything is black and the steering wheel cannot be heard to unlock, the mirrors do not open and after about 5 minutes it comes back to normal. I want to mention that I changed the remote control battery and the 12v battery with a new one.
Many thanks
This thread is for Beta testing, not for diagnostic work and this forum has a Diagnostic and Maintenance thread this topic would have been more suited to!
ElRettentő
- Vehicle: Modeo V, 2.0 Diesel, 132kW, 2015
Hi, my question is that can the IPC modul always show the selected gear, not just when I put it in Sport or manual shift a gear?
