ELiteautosounds
Vehicle: Lincoln Navigator 2021
Post by ELiteautosounds »
This may be a dumb question but how can I find the codes for a specific vehicle? Where are you guys getting the info for the spreadsheets? Please let me know
JackDaniels1171
Vehicle: 2018 Ford Fusion Platinum Fwd
Post by JackDaniels1171 »
The Ford Explorer Spreadsheet by Platinum Owner has been modified it not longer includes the Sync 3.0 column which which had the codes for displaying heated and cooled seats on APIM. I do not know if that column was deleted by accident or not, but luckily for me I had already done the done the modification to display heated and cooled seats on the Sync 3.0 screen along with heated steering wheel controls on both by 2018 Explorer Limited and my 2018 Fusion Platinum.
sg_frost
Vehicle: Transit custom, 2.0l 170PS, 2017
Post by sg_frost »
Does anyone know how to turn on the rear speakers in a transit custom 2017 please. All wires are there, can’t find any options to do it.
Thank you
bill32399
Vehicle: 2015 Ford Explorer
Post by bill32399 »
philipmvg
Vehicle: 2011 Ford Expedition XL
Post by philipmvg »
Souza wrote: Wed May 20, 2020 2:44 am
cdahlen wrote: Sun Jan 19, 2020 5:17 am I have a 2011 expedition. Scanned it and BCM module doesn't show up. Am I not looking at the spot? I was able to enable daytime running lights. Also thought I fixed hyperflash due to LED Turn signals, they blink normal without the lights turned on, but if I turn parking or head lights on they will hyperflash. Anyone have any thoughts?
How did you get to enable the daytime running lights?
Your help would be greatly appreciated.
How were you able to enable DRL without a BCM Module? I have a 2011 Expedition and I can't find a BCM either.
Jackson2999
Vehicle: 2011 Ford Escape XLT 3.0L
Post by Jackson2999 »
Are any Ford Escape decoded as build data available was wanting to change up the IC a bit like getting the digital speedometer on information display without having to go into engineering demo mode every time
PrzemoSmax
Vehicle: Ford S-Max 2.0 diesel 2013r
Post by PrzemoSmax »
Witam
Jestem nowy i narazie się uczę obsługi forum i
szukam pliku z kodami dla forda s maxa z 2013r.
kibromtech
Vehicle: explorer 3.5 2105
Post by kibromtech »
it is very helpful information. thank you fore sharing the info. need to know 2015-2020 ford F150 on on which block is the PCM VIN IS WRITEN ? IF U HAVE SPREADSHEET FOR PCM PLEASE SHARE. APPRICATE
blaiseb1979
Vehicle: Escape, 2.0 Ecoboost, 2013
Post by blaiseb1979 »
Jackson2999 wrote: Wed Sep 15, 2021 3:15 pm Are any Ford Escape decoded as build data available was wanting to change up the IC a bit like getting the digital speedometer on information display without having to go into engineering demo mode every time
Did you ever get a response on the escapes? I've got a scanner delivering soon and want to do some coding.
jimhartman69
Vehicle: 2021 Ford Expedition XL STX
Post by jimhartman69 »
If my Expedition showed Module Configurations could I adjust for tire size? Is there a way to update or make forscan show the body Module Configuration?
