Where to buy a compatible adapter?
Re: Where to buy a compatible adapter?
Looking to purchase a MX+, but was wondering if you guys have an affiliate link or something that I can click on to "wet your beak" so to speak?
There's a metric ton of knowledge here and I know it takes some time, effort, & dinero to keep it all running and thought that if there was something like this I'd like to do my part and help out w/ a click and purchase.
So its October 7 2019 do we have a definitive answer yet here? Is the obdlink mx+ the end all be all? Does it support coding all modules and whatnot? The only recommended adapters that FORscan will lay claim to on all fronts pretty much are impossible to get
veketash
- Vehicle: Mazda Mazda 3, Y6 engine 1.6D, 109 pk, 2010
I own a Mazda 3 2010 1.6D. Do I nees to look for HS/MS CAN support or is that only something specific for Ford?
navyvetharleys
- Vehicle: Ford Focus Engine: Zetec Capacity 2.0L 2000my
I have been using this adapter for over two years used on 2005 Jetta., 2000 ford Focus and 2007 Mazda 3 all with no problems at all.
Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Check Engine Light for Android - Compatible with Torque Pro
by Panlong
https://www.amazon.com/dp/B00PJPHEBO/re ... ljaz10cnVl
by Panlong
- Vehicle: *** Ford ***
Wife got a Mazda3 2010 ...veketash wrote: Mon Oct 14, 2019 5:10 pm I own a Mazda 3 2010 1.6D. Do I nees to look for HS/MS CAN support or is that only something specific for Ford?
When using ForScan ...right at the beginning program wants to know if Elm Unit got a switch ...
Yes ... Mazda uses both HS and MS
For Ford HS-CAN MS-CAN Mazda Forscan OBD2 Diagnostic Scanner USB Modified ELM327
New to the forum today. Forscan rookie. I just hoped up to my truck with elm327 and version 2.3.26. It recognizes all aspects of the truck but when I want to access and change anything it says I require "extended license. How do I get this and does it cost anything. Thx
extlic.php
https://forscan.org/howto.html
PS ...
Also have a read here ...Just in case you got problems : http://forscan.org/forum/viewtopic.php ... 5&t=5775
PS ...
aircraftru
- Vehicle: Insignia, A20DTE, 2000cc/96kW, 2014
Just got a friend with Ford SMax 2009 and try today with my Viecar obd reader. Have issue with parking sensors and change/code/program system from front/rear to only rear
and front not working, but rear working. Will try to attach images here or to external server. Post link for device.
Viecar obd
Images
Viecar obd
Images
1320Technologies
- Vehicle: Mustang Cobra, 4.6L Teksid, 300hp, 1998
New user...
Has anyone tried Autometer DashLink to link via BlueTooth to FORScan?
Otík
- Vehicle: Ford Galaxy 2.2 TDCi Ghia, 2008
I have ordered obd2 adapter Vgate iCar2 Wifi version for my Ford Galaxy MKIII, MY2008, 2.2TDCi, 129kW.
Can you please let me know if this adapter is able to switch to MS-CAN? If not, is there any manual/ guide how to do that?
Thank you for advice
