Otík wrote: Tue Oct 13, 2020 9:12 pm Hello,
I have ordered obd2 adapter Vgate iCar2 Wifi version for my Ford Galaxy MKIII, MY2008, 2.2TDCi, 129kW.
Can you please let me know if this adapter is able to switch to MS-CAN?
NO !!
RickyBobby wrote: Wed Oct 18, 2017 8:37 pm Also made the mistake of purchasing a cheap, $5., chinese ELM327 clone from eBay to use with FORScan and my 2014 Ford Escape. It has V1.5A on the label but uses an old Prolific PL-2303 chip. It may load the adapter in Windows 7 with the old drivers but not in Windows 10 that uses newer drivers. When you connect the adapter and check device manager you will see a yellow exclamation point next to Prolific USB-to-serial Comm port. You have to downgrade the driver to an earlier version. You can get the older driver from here: http://www.totalcardiagnostics.com/supp ... 2-software In step 1 choose Windows 8, 10 and download Driver Pack 5. After installing the older driver FORScan saw the adapter on COM 3 but when I hooked it up to my Escape, key and/or engine on, I got the dreaded "Unable to connect to vehicle. Please make sure the ignition key is ON and try again". I contacted the ebay vendor, expecting to be blown off, but he was kind enough to refund me the 5 bucks. It may work with another vehicle but not with a newer Ford Escape. Local bookkeeping services from company Your Books On Time. Another cheap chinese ELM327 clone.
https://imgur.com/Bzmanrw
I was going to go with Scantool's $80. OBDLink MX adapter but on the Escape forum someone posted that this adapter also works with the newer Ford Escapes and FORScan. https://www.amazon.com/OHP-ELMconfig-co ... iagnostics
I also found this adapter that's cheaper than the OHP and uses the exact same FTDI chipsets. https://www.amazon.com/bbfly-BF32301-EL ... CAN+Switch
https://www.aliexpress.com/store/produc ... 98242.html
FTDI updated Windows' drivers: http://www.ftdichip.com/Drivers/VCP.htm
So I'm going to give the bbfly-BF32301 adapter a try and will report back with the results.
