We need to get one going for collaboration.tigerpro357 wrote:Was there ever a document that's relative to the Taurus made? I found one for Fusions but most of the bits appear to be different from what I have found while testing with my '13 SEL, I was able to activate AWD guage, Nav, Backup Cam (need to get one now) set the chimes to go through the radio speakers (sounds more appealing that way) and so.etching called dark mode which from what I can tell turns the screens in the gauge cluster off when you turn off the ignition. I would like to enable a couple other features but trying to compare a fusion to a Taurus is like trying to compare an apple to a orange
Ford As Built Data Deciphering
FiveLeeter918
- Vehicle: 2013 Ford Taurus SHO
- Contact:
Re: Ford As Built Data Deciphering
- Lee
2013 Taurus SHO PP
AWD gauge, EQ presets, Nav in Motion, Double Honk Deactivated, Signal Flash increased to 5, Engine hours enabled, DRLs enabled
2013 Taurus SHO PP
artiecourville
- Vehicle: 2017 Ford F250
Has anyone experienced the lost of your cruise control and collision guidance after programming the following and how do you get them back? I programmed DPF percentage, Temp readings above gauges, and power point time out.
ClockWorK
- Vehicle: 2015 Taurus SHO pp
- Contact:
That's a strange error I haven't seen before. Hopefully someone from the FORScan team can respond on this one.FiveLeeter918 wrote:Good afternoon all, stumbled upon this post while looking for ForScan mods for my 2013 Ford Taurus SHO. My car is a PP with the 401a technology package, so most of the hacks that I found I already have.
I am especially interested in the AWD monitor, and would love to view the TPMS individually but from what I am ready it is only for 2015+? Bummer.
I tried the code change in the the first couple of posts, but could not get the changes to take effect. I get an error upon trying to write the code. Any ideas?
The AWD bits look correct to me from the screenshot you included.
If you're changing other things though, I recommend only making one change at a time.
FiveLeeter918
- Contact:
I think I figured out the error is due to not having a ms scan capable dongle. I was using a bluetooth unit Ive had a long time. It gave me read access just failed for editing (at least this is my next thought).
Ordered a hardline unit with switch, it'll be here tomorrow and I'll try again.
I saw some talk about getting Beta access, what else do you gain from that over the standard license?
- Lee
2013 Taurus SHO PP
2013 Taurus SHO PP
FiveLeeter918
- Contact:
Ok got my unit in today. Installed the drivers identified in the manual, and downloaded the ELMConfig Utility file to test it. It reads my VIN, pulls codes and can do basic datalogging, however its showing up "unidentified" in my Devices and when I start Forscan I get "No ELM device detected," wont even get to the Profile screen.
Ideas?
Ideas?
- Lee
2013 Taurus SHO PP
2013 Taurus SHO PP
FiveLeeter918
- Contact:
- Lee
2013 Taurus SHO PP
2013 Taurus SHO PP
ClockWorK
- Contact:
At least one review on Amazon says they had to download latest drivers.
And since it's listed as an Unknown Device, that would be my first suggestion.
FiveLeeter918
- Contact:
Forgot to update. So I figured out that this was a Settings error, as I had to default my connection to "Bluetooth" for my old dongle to work.
I got it connected, was able to view the extended DTCs (finally figured out a code associated for my heated seats not working!), and can view the extended As Built Data HS Scan can't view.
However, still getting the same error when trying to write the changes. I've read on a few forums that it was related to the push button start and them not having the car in ACC mode. But I've tried pushing the button once, twice (allows gear shift moving), and even engine running. Still get same error.
- Lee
2013 Taurus SHO PP
2013 Taurus SHO PP
ClockWorK
- Contact:
I've got push-button start.
I always do mods with the car fully running (in Park of course).
FiveLeeter918
- Contact:
not sure I've tried that since I switched to the corded version. May need to try again.
- Lee
2013 Taurus SHO PP
2013 Taurus SHO PP
