Page 18 of 20
Posted: Sat Mar 09, 2024 8:02 am
by Vincenzo2020
Good morning everyone.
I would like to know if it is possible to have the AS BUILT description for Ford Ford Fiesta Gas 1.4i LPG 16V 71 Kw
Engine code: RTJB - Gearbox: M5 (2013-03>) - Plate: EW047PR - VIN: WF0DXXGAKDEP45976.
I should disable TPMS warning light.
I attach module manufacturing data (as-built).
thank you all and have a good weekend.
Posted: Sat Mar 09, 2024 4:43 pm
by MKK777
BUONGIORNO
qualcuno mi aiuti mi serve il file ab per ford s max 2.0L 163CV 2012
vin WF0SXXGBWSCA68297
NON riesco a trovarlo da nessuna parte ho scaricto piu volte dai link che ho trovato sul forum ma non ha informazione
o se qualcuno lo ha a pagamento non ce problema lo acquisto
per favore
grazie
WF0SXXGBWSCA68297.ab
Posted: Thu Mar 14, 2024 2:55 pm
by ral55
I am getting ready to enable remote start and climate control on my 2013 F-150. Do I need to make changes in BCM/IPC and BCM/IPC As Built or just in the As Built?
Posted: Wed Mar 20, 2024 6:27 am
by Vincenzo2020
Vincenzo2020 wrote: Sat Mar 09, 2024 8:02 am Good morning everyone.
thank you all and have a good weekend.Dati di fabbricazione modulo (as-built) - FordServiceInfo.Com.pdf
Hello everyone, problem solved with forscan.
I went into the IPC module, TPMS configuration and selected not configured.
the TPMS light is now off and in the central menu of the car radio there is no longer the tire pressure reset item.
Posted: Mon Mar 25, 2024 7:34 pm
by antoonio
ral55 wrote: Thu Mar 14, 2024 2:55 pm I am getting ready to enable remote start and climate control on my 2013 F-150. Do I need to make changes in BCM/IPC and BCM/IPC As Built or just in the As Built?
On my Smax i got them work just in Configuration section (between available options). Not in AS Built, changing numbers :).
Posted: Tue Mar 26, 2024 10:40 pm
by tayfun8989
Dostum selam fiesta 2013 camların hızlı inip kalkması için neyi değiştirmeliyim kod var mı
Posted: Fri Mar 29, 2024 4:16 am
by dan_uk
Hi, please could somebody send me the as built data for my 2012 S Max 2.0 (163) powershift?
The VIN is WF0SXXGBWSCE45622
Motorcraft is just giving me blank results :(
Posted: Sun Mar 31, 2024 5:41 am
by sloon
Hello, you don't know where to get the FORScan table for the Ranger Raptor 2022MY
Posted: Sun Mar 31, 2024 5:59 pm
by tractmec
sloon wrote: Sun Mar 31, 2024 5:41 am Hello, you don't know where to get the FORScan table for the Ranger Raptor 2022MY
For AsBuilt try here and find and use the AsBuilt link about half way down the Page: https://www.motorcraftservice.com/quick ... uickguides
If you are not in North America you may have to go through the Home page https://www.motorcraftservice.com/ and chose Canada or the US as your country then open "Free Resources/quick guides and find the "AsBuilt link and open it and type your VIN into the VIN field!
It should return a very long list of the vehicles Modules by Module Hex address(I tried it using the VIN in your Attachment, it is there)!
I usually Save the web page by using your Browsers Print button and "Save as PDF" as well as downloading (using the "Download Button"), the file and down load it directly to or copying it to the "FORScan Calibration Files folder in your Documents Folder!
If you mean a spread sheet you will have to do a Google search for Ranger Enthusiast Forums and see if any one is working on one! These are links to a couple of them but they are US based https://www.fordranger.net/ https://www.ranger5g.com/forum/
That is all I can offer!
Posted: Mon Apr 01, 2024 4:56 pm
by sloon
Thanks for the reply, I meant the units adjustment table.
