Ford As Built Data Deciphering
FiveLeeter918
Vehicle: 2013 Ford Taurus SHO
Re: Ford As Built Data Deciphering
Post by FiveLeeter918 »
That worked! So got AWG gauge and engine hour.
Car is a 401a so it came with nav in the dash, how do I enable DRLs? Anything else worth doing?
- Lee
2013 Taurus SHO PP
AWD gauge, EQ presets, Nav in Motion, Double Honk Deactivated, Signal Flash increased to 5, Engine hours enabled, DRLs enabled
ClockWorK
Vehicle: 2015 Taurus SHO pp
Post by ClockWorK »
DRL's should be an option to modify under the BCM i think. I set mine to use the blinkers as DRLs to get that amber-light cop-car look.
I also changed the tap-blinker from 3 blinks to 5.
FiveLeeter918
Found it! Did the 5 blink mod too.
So no tpms I guess?
- Lee
2013 Taurus SHO PP
ClockWorK
Post by ClockWorK »
No TPMS for 2013 as far as I know. Not sure if the IPC or the BCM or some other module is the limiting factor on that one.
I've been meaning to try:
Audio - Enable Equalizer Presets in Sound Menu (Ford Sync 2 (MyFord Touch) Only):
7D0-01-02 (2013+ MY) xxxx xXxx xxxx
0 (Disabled - Default)
8 (Enabled)
I just look at AsBuilt lists for other vehicles (Explorer, Flex, Fusion) and see what might be universal. Like any of the APIM mods for Sync2 should apply to all vehicles with Sync2 as far as I know.
FiveLeeter918
Great thanks
- Lee
2013 Taurus SHO PP
signalmaster509
Vehicle: 2016 F-150 2.7L V6 GTDI
Post by signalmaster509 »
ClockWorK wrote:DRL's should be an option to modify under the BCM i think. I set mine to use the blinkers as DRLs to get that amber-light cop-car look.
So are you guys changing this using the pre-set options in Forscan or are you manually changing the lines yourself? If so what line in the BCM is the change for DRLs, turn signal flashes, and in the IPC for the AWD Gauge?
FiveLeeter918
Yes DRLs is the drop down presets.
- Lee
2013 Taurus SHO PP
FiveLeeter918
ClockWorK wrote:No TPMS for 2013 as far as I know. Not sure if the IPC or the BCM or some other module is the limiting factor on that one.
8 (Enabled)
It worked! Part of APIM
- Lee
2013 Taurus SHO PP
tishandian0416
Vehicle: 2013 Taurus Limited 3.5
Post by tishandian0416 »
Hi new to here I would like to turn on nav in Apim and ipc and drl for my 13 Taurus limited here is my vin can you help me with what I need to change I will be getting my obd2 reader soon thanks 1fahp2f80dg129396
FiveLeeter918
tishandian0416 wrote:Hi new to here I would like to turn on nav in Apim and ipc and drl for my 13 Taurus limited here is my vin can you help me with what I need to change I will be getting my obd2 reader soon thanks 1fahp2f80dg129396
Check out the screenshots above for what to change
- Lee
2013 Taurus SHO PP
