saveanuvictor
- Vehicle: Mondeo,150hp.Powershift 2.0l,2016
Tested
I'ts Working on Mondeo 2016 2.0 150 PS automaic
I’m having the same issue. Did you ever find a solution?nathanjf95 wrote: Mon Jan 13, 2020 4:23 am I drive a 2015 F-150 and this did not work. I have MyKey turned on to the only key I have. I bought another key and had it cut to program only to find out that PATS programming wasn't an option for me in forscan. I tried this method next, and it was to no avail. After completing the KOER test, I wrapped the key in foil, and turned it off. After turning it back on, with the foil still wrapped, the car wouldn't give me a MyKey option within the settings. So I tried the process again, but this time I removed the foil before turning it back on into the run position, and the vehicle immediately enabled MyKey as it had previously been doing.
Did this work witch my Ford Fusion 2012 SEL ? I have 1 key, and it is programmed as MYKEY.
Ford Fiesta Zetec 1.0T 2014 Removed *No Keyless Entry*
I have removed "MyKey" using FORSCAN by going into IPC (Main) and selecting MyKey as No MyKey. It removed it from my car i get no limitations no alarms at 45mph I can also turn off traction control. I have 1 key no admin key and I also don't have KeyLess Entry
alexjudd26
- Vehicle: 2017 Ford Focus
Re: Ford Fiesta Zetec 1.0T 2014 Removed *No Keyless Entry*
I'm having trouble finding the "MyKey" in the main IPC. Only shows 36 blocks (half of them language settings) but not MyKey. (2017 Ford Focus)Will2418 wrote: Mon Apr 20, 2020 6:01 pm I have removed "MyKey" using FORSCAN by going into IPC (Main) and selecting MyKey as No MyKey
smarty1972
- Vehicle: Fiesta 1.6 econetic
I have managed to delete my key too completely, only had one key when we bought the car and stupidly set it as a my key when messing around in the menus. Had to have the extended licence but we'll worth the money, have also got global closure, got rid of the annoying arrow for gearchange and stopped the alarm if passenger doesn't have seatbelt on etc. All easy to do, this was on a 2014 fiesta.
Worked for me. I have remote start 2017 Fusion.
this worked for me only AFTER I cleared and reset everything in forscan. I have a 2019 Mustabg GT premium, and after reading thru all the post its what worked by pure desperation. I reset, and then ran the test as instructed for forscan lite, but when I "REMOVED KEY FROM CAR" I simply held the key out the window and all the options to clean MyKey showed up. PM me if you my post isn't clear. Im literally sitting in my car clearing the mykey as I'm typing this so I don't forget any details
EDIT: push button start/remote start incase it isn't implied
This Procedure worked on my 2017 Explorer with push button start. Followed directions as written. Windows rolled down so I could gently toss the transponder to a safe place away from the vehicle. Never opened the door until the process was completed.
I got a 2011 ford edge limited with just one keyless remote and shes active to mykey. I got forscan and odb reader plug into my pc .... but i cant erase it ? Help please
