Where to buy a compatible adapter?
Re: Where to buy a compatible adapter?
Gatordog wrote: Is the Scantool one ELM327 compliant? I followed the link, and it does not mention ELM327.
Scantool adapters are built on their own IC STN1xxx, they are fine for CAN bus (both HS and MS), but have no special adantages against ELM for older vehicles. More than, ELM works better (faster) with some old bus. So for your 2000 F-350 7.3 Powerstroke some good ELM327 (even good clone) with all protocols supported (J1850 PWM, ISO9191 etc) would be optimal solution.
Gatordog wrote: I did see this link to a ELM327 on this forum: http://www.totalcardiagnostics.com/shop ... 2-scantool
We didn't try those, but some of our users claim it works ok.
carpulse
Post by carpulse »
Here you can find 100% original ELM327 2.1 (ELM Electronics) based OBD2 interfaces: http://elm-327.eu
wystewart
Vehicle: Mustang GT, 5L, 2014
Post by wystewart »
I'd recommend the real ELS27 with bluetooth option; also has USB capability with bluetooth. The adapter is well built and designed. It works with both MS and HS-can.
Marek
Vehicle: Mondeo mk5, TDCI 2.0, 150KM, 2017
Post by Marek »
Hello
Which to choose ELM327 BT or WiFi, support Protocols: Ford HS CAN, CAN MS, SCP, 9141?
From our experience, Bluetooth components are more reliable, so Bluetooth is preferable than WiFi. However in some cases you have no choice, like in case of FORScan Lite for iOS that doesn't support any other option except WiFi.
The above is correct for wireless adapters only, as USB is still faster and more reliable than any wireless option.
bobdinro
Vehicle: Ford 2000 tdci
Post by bobdinro »
iwe buyed the obdlink MX adapter from amazon, work like a charm, al functions errors free!
janf
Vehicle: ford transit tddi 2.4 120hp 2001
Post by janf »
I recently bought this one: http://www.ebay.de/itm/162002057035 for 25,90 EUR
Seems to work perfectly.
iRich
Vehicle: 2012 Ford Focus mk3 Turnier 1.6 TDCi 85kW/115PS
Post by iRich »
FORScan wrote:
Today I received a Polish interface ELM327 v3 FORD MSCAN HSCAN - Interface USB Vscan STN1170 company VIAKEN
Super work with the Program FORSCAN tested on Mazda 6 2.0 citd 2003
Thanks FORSCAN for such a great program
Note: Viaken v3 feature is that it supports 3 interfaces at once: USB, BT and WiFi. We have tested one and it really works great via USB interface. But we were unable to make it work stable via Bluetooth and WiFi. Were you able to do it?
Hello, are there any news about compatibility with the Viaken Vscan STN1170 WiFi ?
I want to buy this adapter but I'm not sure if it will work. The idea is to have this adapter connected permanent, so I can connect to it with my iOS device or the Laptop. Otherwise I have to buy the USB version and a separate cheap elm327 WiFi adapter.
Best regards
Richard
enzocaporal
Vehicle: eco sport se motor signia 1600 modelo 2013
Post by enzocaporal »
NO ME FUNCIONA CON UN CLON ELM 327 BUETOOTH QUE SE PUEDE HACER
qzem
Post by qzem »
What do you guys think about this http://www.ebay.com/itm/ELM327-USB-modi ... Sw3ydV0HxI ?
