bf mk2 falcon radio codes
gmau69
Vehicle: Ford Falcon BA 4.0L 2003
Re: bf mk2 falcon radio codes
Post by gmau69 »
It is very likely you have a playing up HIM module.
They are pretty common to play up and not to control temperature doors and sometimes a light "tap"brings it up to live, other time resetting it in anyway also makes it working. ICC connectors do fail "cold solder joints", but it usually causes a bit different issues.
Koch1e
Vehicle: FORD BOSS 260 5.4 2004
Post by Koch1e »
Hi I am having problems with clearing the security code error on my mates car. its a dual zone ba xr8 mk2. for some reason the acm dosn't show i have tryed another one and its the same. I have attched an Image of the screen shot of what it shows.Image
xr8 image.jpg (54.53 KiB) Viewed 3634 times
gmau69
Post by gmau69 »
Looks like your ACM is not online, does it power up and you have something on the screen? If you press menu and am together for few seconds , will it come up for 5 minutes?
Koch1e
Post by Koch1e »
Hi gmau69, when I press am and menu it dose power up and everything works. even when you turn it off and try it again i press the am and menu it goes back to what was playing.
gmau69
Post by gmau69 »
Do you have an extend license for forscan? Do you see ACM module under any menu of forscan tabs?
Koch1e
Post by Koch1e »
Hi gmau69 I do have the extend license. I did have the 2 month free and it worked on my ba xr8 ute but when i tryed my mate ba mk2 I can not see the ACM module under any menu. So I purcshed the extend License and I still can not is it on my mate car, but everthing works when you do the am and menu for 5 minutes. All you ever see on his car is the him module, bem module and icc module.
oldtinfords
Post by oldtinfords »
Koch1e wrote: Fri Mar 21, 2025 2:20 am Hi gmau69 I do have the extend license. I did have the 2 month free and it worked on my ba xr8 ute but when i tryed my mate ba mk2 I can not see the ACM module under any menu. So I purcshed the extend License and I still can not is it on my mate car, but everthing works when you do the am and menu for 5 minutes. All you ever see on his car is the him module, bem module and icc module.
Update FORScan to the latest version, delete the saved vehicle profile & reconnect to the car so it scans for all modules. Make sure you're using one of the recommended adapters, not some crap ELM327 or device with a manual switch. Add a photo of the device & a screen snip of the device settings if you still have problems.
You should also be selecting service procedures....spanner icon. ACM module calibration is the procedure that will solve the ACM code being displayed.
gmau69
Post by gmau69 »
That is really strange according to your description. If ICC works for 5 minutes when menu and am pressed and you can control climate and central locking via ICC buttons, then it should be on the list for service functions.
What state are you in? If in WA, I can have a look.
oldtinfords
gmau69 wrote: Fri Mar 21, 2025 8:19 am That is really strange according to your description. If ICC works for 5 minutes when menu and am pressed and you can control climate and central locking via ICC buttons, then it should be on the list for service functions.
If the vehicle profile has been saved using a dodgy adapter or he's using an older incompatible saved profile with a newer FORScan version, there's going to be problems. Recent updates requires that old profiles be deleted, refer to release notes & my previous comment.
If he's local to you, good on you for saying you'll help. Remotely connecting to his laptop to assist is an option too. I've done it hundreds of times to help people if they can't work it out with simple instructional help.
gmau69
Post by gmau69 »
I am not as advanced anymore to do things remotely
I always communicate to the car I am connected to and never use saved profile from previous cars
