Re: P1556 After Delete
Posted: Fri Nov 07, 2025 12:40 pm
And I am *assuming* that bad injector driver = new PCM? I know they can be sent out for repair, but I don't believe I have anyone in my area that does that.boosted_diesel wrote: Thu Nov 06, 2025 8:51 pmpetem wrote: Thu Nov 06, 2025 12:51 pmGood point - no need to swap them back. Either the code will move with the injector, indicating the injector is the fault or it will stay with cylinder 6, indicating a wiring issue. I'll try to get some new copper washers this weekend and if I can get my hands on them, I'll swap them out and let you know the outcome.boosted_diesel wrote: Wed Nov 05, 2025 10:35 pm For them to function correctly yea they should be coded in.
It would probably run without the coding but not properly and at this point we don't want to introduce new problems. That's why we also change the seals to make sure there isn't a combustion leak created. Also you don't need to swap them back, you'll have learned what you need to after the first swap and there will be no further meed to swap anything unless you conclude the injector is actually faulty.
Thanks again for all your help and assistance. It is truly appreciated.
No worries, just bear in mind that if the code stays on that cylinder after swapping injectors then it is wiring OR pcm, as pcm is part of the circuit and is also the source. If it had a bad injector driver on the pcm pcb then it could do the same.
