Important notes about As Built configuration and programming
bwrench
Vehicle: 2006 Mercury Mountaineer, 4.6
Re: Important notes about As Built configuration and program
Post by bwrench »
se9303 wrote: Wed Mar 07, 2018 5:35 am Hi
Anyone have the “As built” data sheet for a 2006 Ford Explorer 4.0 L? I need to turn off the “park aid” function which my truck does not have but after my PCM/instrument cluster was changed/programmed by a shop Forscan has revealed DTC’s related to lost communication with parking assist control module
Update:
I managed to obtain through Ford the module build data (As-built) using the vehicle’s VIN and through ForScan i have access to the As-built data of each module. Looking through the IC module data there are numerous differences in each of the codes
Considering that my stock PCM was replaced with a used unit, would it be safe to edit all modules and enter rhe data as per the As-built data sheet Ford has provided?
I have coded/flashed BMW DME’s but not a Ford PCM and would appreciate any input to know if its safe to do or if anyone can pinpoint what exactly needs to be edited for the disabling of the park aid function
Upon request i can make the As-built information
Regards,
Mark
[When using Ford as built data on a PCM, that will program the PCM with the vehicle configuration that was used on that vehicle when it left the factory.]
originalwizards
Vehicle: Various Ford Fiestas Diesel
Re: Important notes about As Built configuration and programming
Post by originalwizards »
I believe it only shows the injector coding, if the engine requires it, I recently done an injector on the 1.4tdci fiesta 2007 and injectors on this model donor need coding.
rsutton356
Vehicle: F150, gas V8 5.0l, 2010
Post by rsutton356 »
I pulled my "as built" data for a 2010 F150 from Ford and the file name has an extension of xxxx.ab rather than xxxx.abt. Do I just rename the file or do I need to do something else? Thanks
AhmadAlqaderi
Vehicle: Fusion hybrid 2.0liter
Post by AhmadAlqaderi »
ndicars wrote: Tue Jan 29, 2019 2:38 pm Is there a possibility to completely reset a BdyCM control unit?
Or is there another way to solve/bypass the lock?
regards, Andy
based on the what they said, I guess the only way is to change the module
AhmadAlqaderi
how to know if it's write-once or not?
any mark on it?
fordlincscan
Vehicle: navigator, v6 turbo, 2018
Post by fordlincscan »
4. Sync 3 (APIM module) sends its configuration changes to Ford. So if you change something there, Sync will send these changes when connects to the Internet, and after some time you can see them on Motorocraft site. So far there are no known outcomes of this (like loss of warranty), but it is important to known anyway.
Is there any way to stop the APIM from connecting with ford? Why else would you need it to? Unless you wanted to connect to the sync app, I dont see a reason, am I wrong?
I noticed the dealer can also see my vehicle status and location at any time, existing codes etc. Im assuming thats part of it connecting with ford.
royal2002
Vehicle: ford explore v6 2021 base
Post by royal2002 »
100% agree :ugeek:
luigimita
Vehicle: Ford Kuga 2022 ST-LINE 1.5 Ecoblue 120cv
Post by luigimita »
these are different points:
1) APIM send automatically some changes, like sw update, calibrations and map versions. This work now
2) TCU module send to Ford servers, information about DTC codes and something else. This help in case of support or random problems.
The only way to disable automatic sending of information is turn off TCU.
AdrianPeters
Vehicle: Ford Mustang 2015 5.0 Automatic
Post by AdrianPeters »
Hello, I'm looking for advice on a 2015 Ford mustang. I replaced the BCM but the new BCM has steering column lock module enabled but the car does not have that module. When trying to write asbuilt data I get the message ( Irrevesible data change detected You are trying to modify the block 726-22-02 byte #3). I’ve tried updating the BCM with FJDS but block 726-22-02 changes only partially and not to what as built data is. And after reprogramming the cab lights flash
An92
Vehicle: Mondeo, 2.0 St-line 2021 Full hybrid
Post by An92 »
Good evening, for my Mondeo Hybrid purchased used in 2024, I have several files downloaded from the Motorcraft website, one downloaded on December 16, 2024, May 11, 2025, and March 31, 2026. All the files have a different size in bytes, but with the Asbuild Explorer software they appear the same. Do you know the reason? Over time, I have performed several firmware updates with Forscan or configuration changes. I have a Sync 3 with TCU. Thanks.
