Page 3 of 5
Posted: Sat May 23, 2020 8:30 am
by fordsmax471
Hi !
The Shift Fork System and Clutch System Learn \ calibration procedure was successful ;)
Mondeo 2007-2014, 2.0L Duratorq DOHC(150/163PS)-DW10C Powershift 6DCT450 (MPS6)
FORScan version 2.3.33 beta for Windows
Posted: Wed May 27, 2020 6:52 am
by ecudoctor
I have problems with learn too.
Not possible fork learn. The car don't go to D and R
Posted: Wed May 27, 2020 7:32 am
by fordsmax471
ecudoctor wrote: Wed May 27, 2020 6:52 am I have problems with learn too.
log :?:
Posted: Sat Jun 13, 2020 8:04 am
by camope
It doesn't work for me either. My car is a S-max Duratorq 2.0 from may 2010 and has a electric parking brake.
I have tried several times the Clutch System Learn procedure without success. It seems to start but after a while it finishes with error.
has anyone done it with similar model?
Thanks.
Posted: Sun Jul 19, 2020 11:10 pm
by richardc1983
I've performed this today on a mk3.5 focus ST3 did a MODULE reset first then a clutch system learn then the fork learn. Took many attempts to get it working. Does this function replace the adaptive learning I see posted on the forums as cannot find adaptive learning anywhere.
Posted: Sun Oct 25, 2020 11:21 am
by Plushly
Did you ever resolve this issue? I have the exact same TDC and "Clutch Ventilation Learn - ERR"
Posted: Tue Nov 24, 2020 3:14 pm
by Rivelino
Because i receive PM from users who ask what i do for that, but they don't even bother to check theirs emails.
I'll post what i do.
,,Hi,
Question: do you made a a clutch work ? (replace clutch plates and the car make engine like crazy when you try to shift gears?)
Because that i do.
After a long search , i resolve it my self.
I remove TCM from car to clean (7-th time) , undo screws who keep tcm to gearbox in same worder of tightening.
Undo screws for electrical conector and speed sensor!!!!
Because i forget to remove speed sensor , i torned flexible band.
Undo screws from halfs of body.
Remove first half of the body, then carefully the one with sensors.
Check pistons for ,,impurities" on first half body and clean.
Pistons should be work freely.
Also is a solenoid responsable for Clutch ventilation.
All solenoids must have about 3-4 ohm.
You can test it with adjustable voltage source , at 8 Volts 3 Amps.
Clean solenoid with out power applied and also with power.
Also i create a demagnetizer for solenoids.
Watch videos from YepThatsIt also from DimaDima (use automatic translate from russian)
https://youtu.be/TjJTfq9NMVw
Put it back in reverse order.
All big screws is tightening in 2 stages. 5 Nm then 10 Nm.
I buy it a torque wrench (adjustable) who can tight at 10Nm .
If do you have gearbox on car is a little bit hard.
https://youtu.be/jxCEdxT2_Rk
After put back oil in that order:
-Fill until pouring on level.
-Start engine for 10-20 seconds to start oil pumping in valve body.
-Start to put oil again until TCM compartment is full (you can see where is level after remove valve body) and pouring on level
-Start engine until 40 degrees C change gears 20 sec.
-Open level screw leave to pour and refill with oil.
(If you clean very well gearbox you can reuse oil, filtered with 190 grit filter buy it from shops selling paint for cars)
Forscan:
- Do clutch learning !!!, NOT fork learning!!!
Regards,
Rivelino"
Hope is helping.
Posted: Tue Dec 28, 2021 8:27 pm
by FoMo4
Hello.
I have problem with Clutch learning. Full repair, new clutch and many other things, try with two different valve body (both fully working after repair), and every time procedure is interrupted after Clutch Boost Learn. Revs go to 5000 (not to 3000 as usual). Try different FORScan versions too. Any suggestions? Thanks!
Posted: Tue Dec 28, 2021 8:48 pm
by fordsmax471
Kuvatõmmis 2021-12-28 224741.png (47.44 KiB) Viewed 6403 times
Posted: Sun Jan 09, 2022 4:28 am
by jayvee
Hello, did you ever get a fix? i have the same problem with the rpm in boost, only i get the tc p0949-00 2f thanks john.
