Page 22 of 36
Posted: Mon May 18, 2020 6:51 pm
by jpmartinho78
One more here, to try ou the 2.4.1 version, if you would be so kind. Thank you
Posted: Wed May 20, 2020 12:39 pm
by timstanley1985
timstanley1985 wrote: Sun May 17, 2020 11:54 am Hi, I have just bought an obdlink ex. Is a 2.4 beta still available to test out updating module firmwares?
Hi, it doesn't look like Forscan are distributing this beta anymore. I only need to update my APIM so it works with sync 3.4. Would somebody who already has the beta be willing to share?
Posted: Sat May 23, 2020 5:40 pm
by timstanley1985
There is a link to a copy of 2.4 beta at the link below. Make sure you read the warnings in the second post if you are planning on updating your APIM. Sound like a right pain in the ****
https://www.f150forum.com/f118/upgrade- ... ns-458828/
Posted: Tue May 26, 2020 12:23 pm
by LaForge
Yeah, APIM is awful and may result in loss of module.
regards
Karsten
Posted: Tue May 26, 2020 12:24 pm
by LaForge
RCM relearn and Software Upgrade is not possible on Focus MK3 2011 (I guess till 2018 too)
Does not work with Beta 2.40 from April 20
If you need, I can send you the Log Files
regards
Karsten
Posted: Fri May 29, 2020 12:47 pm
by Boyc123
I have Focus mk2.5, 2011 year. Is with FW update possible to activate mirror folding at car lock? Currently I don't have this option in DDM and PDM modules, but I can fold them with button inside car. I find that this is possible with UCDS, but I don't have their adapter. I have ELM327 with HS MS CAN switch.
Is there new FW for those two modules, so it can be done through FORScan update, and then activate folding option?
If it's possible, I would like to try it?
Posted: Fri May 29, 2020 3:35 pm
by jw1982
The firmware update functionality only supports last generation modules. Modules of older Ford models like the Focust MK2.5 are not supported.
Apart from this the autofolding functionality when unlocking/locking the car requires custom (commercial) firmware. This custom firmware is available as a paid function (requires tokens) of the UCDS system.
Posted: Fri May 29, 2020 4:52 pm
by t4thfavor
I'm looking to be able to update the firmware on a 2019 Ranger PCM. I'm specifically looking at two AB files, both have the normal 163-xxx codes, while one of them has a large list of 165-xxx codes. I "believe" this is to enable the Trail Control feature, and would like information on how to flash the FX4 firmware to the non-FX4 truck.
Thanks,
Chance
Posted: Fri May 29, 2020 5:55 pm
by lordwader
when we can expect release of forscan 2.4.1?
I would like to update firmware in APIM (non Navi) 2018 module in Kuga from2018 with viaken STN1170. Is it a big risk?
Posted: Sun May 31, 2020 10:25 am
by dursun_7885
nice function. I can“t wait to use it.
mail : dursun.goktas@tai.com.tr
