OK
Yes I will, it will remove the incorrect calibration.
Testing firmware update function for Ford modules
Re: Testing firmware update function for Ford modules
Hello guys, I hope you are having a great day.
I recently got sync3 kit and it would be helpful if I got Forscan 2.4.
Unfortunately, it didn't help. LA still doesn't display the line.
I would Like a copy of the Testing Version of Forscan
Hello
Is it possible to get the newest test -software?
tamopero1910
- Vehicle: Focus 1.5 110 2015
After *.vbf calibration update of the BCMii with IDS 117 on a CMAX MY2015 the DTC shows checksum error.
Forscan can still connect the car, but IPC and KEYS do not work. I would like to try a *.vbf calibration update with Forscan, which version can i use?
amr.alansari3
- Vehicle: Ford,crawinvctoria, v8,236hp,2004
please send me forscan 2.4
i want Testing firmware
I wish I had a copy of the 2.4 as well. Would like a copy so I can update the APIM in my f-150
On my focus mk3 with sync 3 I have the black screen problem, I read that this can usually be fixed by re-flashing the APIM.
Hence I would like to get access to the 2.4x version so that I can perform the operation, can I get a link to the file?
I don't have much to lose as the sync 3 is already "dead" so re-flashing can not make it worse
Thanks for the help.
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
If its dead, then you are stuck.JensG wrote: Sun Jun 14, 2020 9:35 pm On my focus mk3 with sync 3 I have the black screen problem, I read that this can usually be fixed by re-flashing the APIM.
You have to use UCDS and the "flash Dead Module" function.
If you cannot find the module with Forscan, you cannot flash it.
This will be a nice idea for future versions.
A "Flash Dead Module" function, there you have to set the kind of module and Forscan will flash brutally to the desired address.
Then it may reflash the module to get it work again.
At this way UCDS has saved my IPC which was killed by me, trying to flash Focus FL features to vFL Software.
Best regards
Karsten
Changed on my 2011 Focus:
Hill Assistant, Auto High Beam, Sync 3 with Navigation, Traffic Sign recognition, Lane Keep Assist,
Lane Centering Aid, Rain Sensor, Ambient & Footwell Light, FL ST-IPC, BLIS, HSW from Focus FL.
