Did you try here?: https://www.motorcraftservice.com/AsBuilt I just found it for the VIN you posted above! You can also get to this Data from the https://www.motorcraftservice.com home page by opening the "Free Resources" tab and "Quick Guides" link and scroll down to the "Module Build Data(AsBuilt)" link!Kronos_2000 wrote: Tue Sep 20, 2022 1:57 am help me, code abs used information.
I'm not getting it on the site.
can anyone get it for me?
VIN 9BFZB55P4D8808773
Fill out the VIN information field and the Security Check field and you will get a page that you can print with the browsers print button command(easiest to read and the ABS module are the 760 address's) or download as a text file with the Download button as a <YourVINNumber>.ab file which will open in Notepad or any text editor but it is harder to decipher!
The Load Factory AsBuilt button in the FORScan Configuration(AsBuilt Format) section will also go out and do this for you(computer must have a valid internet connection while connected to the vehicle for this)!
Hope this helps?
