Mazda CX-5 2.2 SkyActiv-D - DPF filling fast
Mareng
Vehicle: Mazda 6 Diesel, 2.2, 2014, Britain
Re: Mazda CX-5 2.2 SkyActiv-D - DPF filling fast
Post by Mareng »
Sometimes the sensor pipes for Exh Pressure sensor 1&2 become blocked.
Remove senseors from rubber pipes and trickle some washing up liquid and water down them. Also remove the MAP sensor and check if its covered in carbon, this will sometimes cause juddering of engine when starting from stop as the ECU does not receive the correct signal.
This can be cleaned with washing up liquid, then lightly with an old tooth brush. If you are rough and you damage the sensor then you will need a new one.
Using a endoscope attached to a tablet or phone with the software you can use the MAP sensor hole to inspect No.1 inlet port and valve for carbon build up, itvwill look like ice as the black turns white in the lights.
Partially carboned inlet valve
It is quite easy with a very modest tool kit to remove both EGR valves ( one is a bypass) the pipes you take off and the EGR cooler just using washing up liquid and water , tooth brush. The cooler you can attatch a blank one end and add the soap and water, keep giving it a shake, best left for a few hours and use boiling water first time. If you can leave it over night , even better, then rinse outwith a garden hose( you don't need a pressure sprayer) until it runs clear.
Reassemble adding a smear of Copper based grease to all the threads. This should be standard practice when working on the car
If you think your DPF is blocked, it could be something to do with either the sensor pipes or bad combustion. You can add washing up liquid and water via the two HP side sensor tubes as they attach at the begining of the DPF , after the CAT and the soap will help dissolve carbon in the DPF. Best done over a weekend , keep adding the liquid. The No.1 Exh Pressure sensor is attached to the DPF via a banjo and banjo screw and these have been known to block up.
The banjo is removable , but its very difficult to reach from the top, so if you can clean it chemically and check it occassionaly that will help.
They are a good car apart from a few of these maladies. One person I know when he removed the banjo screw, drilled the hole out slightly, reducing the chance of blockage, but don't go overboard.
A lot of town driving are the death of these engines.
Have a look at this chaps videos, he is very good.
https://youtu.be/77sm3p-4uuQ?si=CN4qx0Q36GTTPoz1
He mainly only deals with Mazdas and 2.2d's in any of the cars that have them. He has a lot of videos out on U-tube on various 2.2D problems, so worth a look.
toshe11
Vehicle: Mazda 6 2.2D Skyactiv 2013
Post by toshe11 »
I want to say my experience on the DPF fast filling problem. When the DPF regeneration process is running at the end of the process, the DPF PM ACC DSR parameter should reach 0 or 0.1 - this means that the DPF filter is completely cleaned and has full volume. If this parameter does not reach lower values ​​than 0.3-0.6, then the filter remains dirty even after regeneration and does not work with its full volume. My experience shows that this occurs when a small amount of oil passes through the turbocharger and is deposited on the DPF, after which the high temperature turns this oil into solid oil coke particles into the DPF. This reduces the volume of the DPF and it fills up with soot faster. In this case, the dpf must be cleaned on a special machine - for example - https://www.youtube.com/watch?v=dAxXfR0 ... DPFRefresh
spektr
Vehicle: mazda 6 2.2
Post by spektr »
Indeed. Yesterday i made a efr delete from my 6. This is the whole new dimension when driving the car. Almost 1l lower consumption, less heating - oil temp, and more responsive engine. Next step is to again do the carbon cleaning, and this will be it I hope as far as cleaning of the inlet manifold is about.
mrfox
Vehicle: Mazda CX-5, 2.2 Diesel 175BHP, 2016
Post by mrfox »
Hi everybody.
I know this post is quite old but I wanted to share my experience around the DPF filling fast issues.
I've been going through all the pages and found some information that I would like to more about.
I have the Mazda cx-5 2016, and my ECU was flashed as (by Mazda) as part of the investigation into the frequent DPF regenerations.
Now after four new injectors, DPF, and Exhaust Pressure sensor, fuel filter and DPF clean, I have the regeneration interval at around 110 miles (176km). Reading the entire topic helped me to understand that the new ECU software (I have the PCM calibration version J) forces the regenerations at a lower PM value than the older version.
I noticed that some of the forum members flashed their own ECU. Could I ask what you used?
I am toying with the idea of buying the tool, and my question is:
Do you have to pay extra to get the different ECU software versions or does it come with the ECU mapping software?
I would like to flash it back to the 2017 version.
Does the tool allow you to do a stage one remap?
Thanks!
zdarova
Vehicle: Mazda cx-5 2.2 diesel 175hp 2016
Post by zdarova »
@mrfox,
I used the device from ecutools (Estonia if I remember well), they shipped me the device and the key to use it. Around 120 euro if recall correctly.
Then I bought the ecu map from jecdu33 aatt gmail dott com, 50 euro.
Everything worked just fine. Note that you neet a windows laptop.
My experience after 9 months is that is not worth it, invest the money in a local good mechanic, troubleshoot if diff sensor, the exhaust camshaft, little/big turbo, intake, Egr cooler or the oil strainer are ok, the injector are the last to fail ... the ECU tuning won't solve the issue long term ...nor the EGR chip off, that could potentially ruin your engine because you'll not warm up the engine correctly.
Please check the videos from MrNiceGuy from youtube, he is an onest mechanic from the UK...
spektr
Post by spektr »
I did EGR off a while ago, and the engine is like a charm. Regenerations are now around 300km, before that the regenerations were around 170km.
mrfox
Post by mrfox »
Thanks @zdarova and spektr
I bought the car last year and luckily all the work was completed under the warranty.
I did a fair bit myself, such as cleaning the inlet manifold etc. I actually did it based on the mrniceguy videos.
I don't have any issues with the car to be honest. I just would like to get the some more distance between the regenerations as they affect my fuel economy quite a lot 😂
spektr wrote: Mon Dec 09, 2024 12:56 pm I did EGR off a while ago, and the engine is like a charm. Regenerations are now around 300km, before that the regenerations were around 170km.
Sadly this is illegal in the UK so I'm a bit concerned what it would come to if it was found
spektr
Post by spektr »
It won't. :)
mrfox
Post by mrfox »
Hi spektr
Sorry to be replying after a very long time.
I have now flashed the ECU and did the EGR off, but it seems that the PM gen value rises slightly quicker than before, while the PM acc stay very low.
Could this be because of the version of software I had prior to the remap? The modified file was based on the version J.
Stage 1 remap and EGR off.
What file is your modification based on? Do you have stage 1 remap + EGR off or just EGR off?
Thanks!
spektr
Post by spektr »
My PCM version is G.
How many kilometeres do you have between the regen?
