Fiesta MK8 Active park assist retrofit guide
Ghano38
Vehicle: Ford c max
Re: Fiesta MK8 Active park assist retrofit guide
Post by Ghano38 »
If the ACM and PAM as built’s did not bring the sound back you have to check out again the APIM configuration,in the Focus mk3.5 the parking aid button works differently than the mk3,if it’s pushed the sounds goes off Have a look her
https://community.cyanlabs.net/t/enabli ... ade/555/96
pierogi
Vehicle: Ford Escape 2.0 SE 243km 2017
Post by pierogi »
I don't think we understood each other - the sounds from the front and rear sensors can be heard. The only thing you can't hear is the sounds when he finds a parking space
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Ah ok sorry, though you have no sound at all,mine is not working at all since last month,when i press the button and a parking place is found the message in the Sync3 is not showing any more since a replaced right external sensor.
pierogi
Post by pierogi »
Hi - I didn't solve the problem. Tomorrow I will change the 15T850 module to 15K866 and keep fighting.
I think I tried all combinations in PAM and nothing :(
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
pierogi
Post by pierogi »
Thank you for Link. I read everything. Unfortunately, I haven't found a solution. The problem is in the IPC in the case of the Ford Escape.
pierogi
Post by pierogi »
Hey
Park Assist audio issue resolved.
IPC is responsible for the sounds of automatic parking in Ford Escape 2017:
720-02-01 xxxx xxx0 - no chimes
720-02-01 xxxx xxx4 - there are chimes
It works for me :)
Escape SE 2017 with added parallel and perpendicular parking assist on both modules 15T850-Bx and 15K866-Bx
Thanks for the tips
Regards
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Happy to hear this,unfortunately Forscan does not have direct configuration for all modules except for BCM and APIM in most cases with UCDS you can do this and have more visibility when programming modules.
pierogi
Post by pierogi »
Yes you are right. It's a pity that the UCDS project has been suspended. I'd like to buy it because I'm going to add more modifications to my Ford.
PeterEgran
Vehicle: 2018 Fiesta MK8 / 2022 Puma ST / 2022 Kuga ST-Line
Post by PeterEgran »
is there a button available without the Start/Stop switch?
