Thank you for this. I was able to fix the SECURITY CODE ERROR deleting the saved vehicle profile. but i still don't see the ACM module in the configuration and programming.oldtinfords wrote: Fri Mar 21, 2025 4:20 amUpdate FORScan to the latest version, delete the saved vehicle profile & reconnect to the car so it scans for all modules. Make sure you're using one of the recommended adapters, not some crap ELM327 or device with a manual switch. Add a photo of the device & a screen snip of the device settings if you still have problems.Koch1e wrote: Fri Mar 21, 2025 2:20 am Hi gmau69 I do have the extend license. I did have the 2 month free and it worked on my ba xr8 ute but when i tryed my mate ba mk2 I can not see the ACM module under any menu. So I purcshed the extend License and I still can not is it on my mate car, but everthing works when you do the am and menu for 5 minutes. All you ever see on his car is the him module, bem module and icc module.
You should also be selecting service procedures....spanner icon. ACM module calibration is the procedure that will solve the ACM code being displayed.
bf mk2 falcon radio codes
Re: bf mk2 falcon radio codes
oldtinfords
- Vehicle: 06 BFII XR8 260kw,08 BFII GT 302kw,07 BFII XR6T 245kw
A lot of people have issues when replacing an ICC because they don't do it correctly & it takes modules offline.Koch1e wrote: Mon Mar 31, 2025 4:00 amThank you for this. I was able to fix the SECURITY CODE ERROR deleting the saved vehicle profile. but i still don't see the ACM module in the configuration and programming.oldtinfords wrote: Fri Mar 21, 2025 4:20 amUpdate FORScan to the latest version, delete the saved vehicle profile & reconnect to the car so it scans for all modules. Make sure you're using one of the recommended adapters, not some crap ELM327 or device with a manual switch. Add a photo of the device & a screen snip of the device settings if you still have problems.Koch1e wrote: Fri Mar 21, 2025 2:20 am Hi gmau69 I do have the extend license. I did have the 2 month free and it worked on my ba xr8 ute but when i tryed my mate ba mk2 I can not see the ACM module under any menu. So I purcshed the extend License and I still can not is it on my mate car, but everthing works when you do the am and menu for 5 minutes. All you ever see on his car is the him module, bem module and icc module.
Remove the ICC. The connector in the dash has a white section inside the outer black section. You need to pull the inner white section out towards the rear of the car until it locks in place. This helps with the correct installation & electrical connection. Usually there will be additional cluster issues if it's not fully seated.
There are several fuses for the ICC, so make sure you test all of them.
It could also be a CANbus issue, it's not seeing the PCM & if it's fitted with ABS, it's not seeing it either.
Help yourself by providing what has been requested about the cable type & settings if the above doesn't work.
