carguy24
I used forscan just fine with cardaq-m
carguy24
I was successful using cardaq-m with Windows 7 version of forscan...I don't have the extended license yet so I havnt tries the programming..but diagnostics worked well with my interface
DanMc85
- Vehicle: Fusion, 2.0L GTDI, 2014
- Contact:
Here is the Bosch VCI Manager 2.3.85.7 dedicated driver and firmware update package for the Ford VCM II... it has been available for a while now. At least a year, but just saw this post lolFORScan wrote: May be someone will create a dedicated drivers package for VCM2 some day.
http://www.boschdiagnostics.com/pro/sit ... 3.85.7.exe
Allows the VCM II to be used with J2534 applications without installing full blown IDS software.
Source: http://www.boschdiagnostics.com/pro/sof ... ord-vcm-ii
Note: Some older china clones will not work with this version unless they support IDS 97+, if not then an older driver package is needed.
Older versions, such as 2.1.119.3 (IDS 91-95/96) OR 2.1.1.5 (IDS 86)
Hello I have tactrix openport 2.0. I fail to use with forscan 2.3.2. Can anyone guide me ?
Looked at august 2016 transit last week, tried ids no joy ( to be fair the ids has not been updated for a while ) then
tried forscan with a drewtec JLR mongoose and had access to a cardaq plus, both worked fine with MS and HS can.
have also used JLR mongoose on a 1999 focus and a 2002 mondeo. I believe the focus still had some old iso modules
so it seems iso \ 1850 pwm \ ms can \ hs can are all working .
Here are a few images with a 2007 Ford Focus North American Version with the Actia PassThru-XS.
Good success and quick to diagnose. The software was stable and connected quickly.
- AnyC00006.GIF (22.73 KiB) Viewed 29240 times
- AnyC00005.GIF (28.87 KiB) Viewed 29240 times
- AnyC00004.GIF (33.34 KiB) Viewed 29240 times
Image of 2007 fiesta, exactly the same with cardaq or jaguar\landrover mongoose
and much faster than elm327
- festa1.jpg (77.49 KiB) Viewed 28977 times
Hi Sid here from Malaysia, connected using Pass-Thru J2534 OP 2.0
response time is faster than ELM327
Really appreciated if developer can update beta test using module as I'm also using OP 2.0 for Toyota and others.
I think OP 2.0 is more stable.
I also have Actia XS IDS and ELM327
Please count me in for beta testing.Thanks Admin!
- forscan OP2.0.jpg (455.86 KiB) Viewed 28883 times
Use latest revision.I mange to connect using OP 2.0.chachawas wrote:Hello I have tactrix openport 2.0. I fail to use with forscan 2.3.2. Can anyone guide me ?
Ashraf6119
- Vehicle: Ford Transit 2.4lt 2008 Diesel
Had a quick play with ForScan software 2.3.4 version on a Ford Galaxy 2009 using Original AVDI PassThru interface and it did communicate with all the modules........will test it later for more functions and report the out come..............
