Testing firmware update function for Ford modules
red4911
Vehicle: Ford Mondeo 4 2.5T/220, 2009
Re: Testing firmware update function for Ford modules
Post by red4911 »
Hello. Does anyone have files for flashing two blocks on Mondeo 4 - acc block - 6g9n-14b588-be and RFA / KVM block - 7s7t-19g481-ca?
Slaawek77
Vehicle: Ford Focus ST 2,0 MY2018
Post by Slaawek77 »
EDIT: Del.
Slaawek77
Post by Slaawek77 »
Ford Edge USA 2016- in order to change the region to PL in IPC, you need to update the soft, from what I heard, the one from Mondeo MK5 will be good. Someone will answer what files should be?
daczone
Vehicle: Ranger, 2.3 ecoboost 2020
Post by daczone »
t4thfavor wrote: Fri May 29, 2020 4:52 pm I'm looking to be able to update the firmware on a 2019 Ranger PCM. I'm specifically looking at two AB files, both have the normal 163-xxx codes, while one of them has a large list of 165-xxx codes. I "believe" this is to enable the Trail Control feature, and would like information on how to flash the FX4 firmware to the non-FX4 truck.
Thanks,
Chance
Did you ever get this? I have a 2020 Ranger (Non FX4) and comparing it with 5 other FX4 models, Same year (2020), Body (SuperCab) and Model (Lariat) and my PCM has the same number of blocks in it.
dega_88
Vehicle: Fiesta ST MK8 1.5 - 11/2020
Post by dega_88 »
hello, a TCU module update is available for my fiesta st mk8 2020. I use forscan 2.46 test 20220309 and obdlink ex. Can I perform the update without problems with the precaution of keeping the car and pc battery under charge?
stimpy88
Vehicle: Ford Mondeo Mk5 - Diesel 2.0, 150, 2017
Post by stimpy88 »
dega_88 wrote: Sat Apr 02, 2022 12:04 pm hello, a TCU module update is available for my fiesta st mk8 2020. I use forscan 2.46 test 20220309 and obdlink ex. Can I perform the update without problems with the precaution of keeping the car and pc battery under charge?
Could I ask where you get this new version from?
Bilsi
Vehicle: 3FA6P0RU4ER278845
Post by Bilsi »
Help please
Any body have EG9T-14G162-DD. Vbf file
I can't find on https://www.fordtechservice.dealerconne ... roduct=IDS website this file for ECU Configuration hardware /BCM FORD FUSION TITANIUM / HYBRID 2014 PLEASE HELP😔
lsdlsd88
Vehicle: Mazda MX5 1.6L 90hp 1996
Post by lsdlsd88 »
found this in another post:
for example Tactrix OpenPort 2.0 doesn't support J1850 PWM, although Tactrix says on their site that they do
does anyone have an official answer as to why they say its not supported but it should be??
Anhkhoi
Vehicle: Ranger Nextgen 2023
Post by Anhkhoi »
Hello
I would like to become a betatester and tasting the update function.
Post by tractmec »
Anhkhoi wrote: Sat Jun 15, 2024 4:08 pm Hello
If you are a Paid license holder you can get the 2.4.xx Beta version on a private thread on this Beta test section! as Far as I know FORScan is no longer asking for Beta Testers and the 2.4.xx concept has changed as per this thread: viewtopic.php?f=13&t=23971
