Page 36 of 36
Posted: Mon Dec 20, 2021 6:30 pm
by red4911
Hello. Does anyone have files for flashing two blocks on Mondeo 4 - acc block - 6g9n-14b588-be and RFA / KVM block - 7s7t-19g481-ca?
Posted: Sat Jan 08, 2022 11:17 pm
by Slaawek77
EDIT: Del.
Posted: Tue Feb 15, 2022 2:10 pm
by Slaawek77
Ford Edge USA 2016- in order to change the region to PL in IPC, you need to update the soft, from what I heard, the one from Mondeo MK5 will be good. Someone will answer what files should be?
Posted: Thu Mar 24, 2022 10:00 pm
by daczone
t4thfavor wrote: Fri May 29, 2020 4:52 pm
I'm looking to be able to update the firmware on a 2019 Ranger PCM. I'm specifically looking at two AB files, both have the normal 163-xxx codes, while one of them has a large list of 165-xxx codes. I "believe" this is to enable the Trail Control feature, and would like information on how to flash the FX4 firmware to the non-FX4 truck.
Thanks,
Chance
Did you ever get this? I have a 2020 Ranger (Non FX4) and comparing it with 5 other FX4 models, Same year (2020), Body (SuperCab) and Model (Lariat) and my PCM has the same number of blocks in it.
Posted: Sat Apr 02, 2022 12:04 pm
by dega_88
hello, a TCU module update is available for my fiesta st mk8 2020. I use forscan 2.46 test 20220309 and obdlink ex. Can I perform the update without problems with the precaution of keeping the car and pc battery under charge?
Posted: Wed Apr 20, 2022 9:36 am
by stimpy88
dega_88 wrote: Sat Apr 02, 2022 12:04 pm
Could I ask where you get this new version from?
Posted: Thu May 05, 2022 2:27 am
by Bilsi
Help please
Any body have EG9T-14G162-DD. Vbf file
I can't find on
https://www.fordtechservice.dealerconne ... roduct=IDS website this file for ECU Configuration hardware /BCM FORD FUSION TITANIUM / HYBRID 2014 PLEASE HELP
Posted: Tue Sep 20, 2022 12:56 pm
by lsdlsd88
found this in another post:
for example Tactrix OpenPort 2.0 doesn't support J1850 PWM, although Tactrix says on their site that they do
does anyone have an official answer as to why they say its not supported but it should be??
Posted: Sat Jun 15, 2024 4:08 pm
by Anhkhoi
Hello
I would like to become a betatester and tasting the update function.
Posted: Sat Jun 15, 2024 6:56 pm
by tractmec
Anhkhoi wrote: Sat Jun 15, 2024 4:08 pm
Hello
If you are a Paid license holder you can get the 2.4.xx Beta version on a private thread on this Beta test section! as Far as I know FORScan is no longer asking for Beta Testers and the 2.4.xx concept has changed as per this thread:
viewtopic.php?f=13&t=23971
