FORScan v2.4.1 release notes
rich935
Vehicle: Ford Focus SE 2.0
Re: FORScan v2.4.1 release notes
Post by rich935 »
omar302 wrote: Wed Sep 16, 2020 3:44 am
rich935 wrote: Tue Sep 15, 2020 2:12 pm Has anyone had a failed module firmware update? What happened? Were you able to fix it?
YEs. Had a BCM Firmware update fail. As I wrote earlier, the car wont start, ignition wont turn on, power windows/locks wont work, Electric Parking Brake won't release. I got a bricked vehicle. Was luck to get special help and flashed back to original firmware. But till that was fixed my car was stuck for more than a day. Again, I was very fortunate that I get assistance & the BCM was able to be reflashed.
Oh ok. What did you use to reflash the BCM firmware? Forscan software or Ford IDS or something else. I'm just wondering. Also what kind of vehicle was it? Thanks
NutztFORScan
Vehicle: C-MAX II (DXA) 1.5 EcoBoost (150 PS), 2017-10
Post by NutztFORScan »
"If something went wrong with the update, you will need to download official ScanTool firmware updater (https://www.scantool.net/scantool/downloads/updates/) and recover it manually."
It should be mentioned, that you better look into the Settings of the ScanTool firmware updater, there you find, BL Baud Rate; 115200. When you open the program you just see the COM-Port and its Baud Rate. Those lazy guys from ScanTool did a "great" job. Instead of setting the default for the COM-Port to AUTO or 115200 you they take the original value FTDI put in here during the installing process – 9600. Not such a good idea, set it to 115200 or the update will fail.
BTW, you mention that a battery charger should be applied, how many amps should the battery charger provide?
RicardoRimer
Vehicle: ford ka 1.0flex brasil
Post by RicardoRimer »
Good night! I use an ELM327 V1.5 and have never had any problems. I acquired a VCM II GM, this one has J2534. Can this interface have all the functions of FORScan?
rich935
Post by rich935 »
NutztFORScan wrote: Wed Sep 16, 2020 6:20 pm "If something went wrong with the update, you will need to download official ScanTool firmware updater (https://www.scantool.net/scantool/downloads/updates/) and recover it manually."
For the battery charger question I did the PCM and TCM update with the laptop plugged in and the battery charger to the car battery at 12v 2amp and it worked fine.
Hope that helps.
nabilultranet
Vehicle: FORD FOCUS MK3 1.6L TDCI 115 2012
Post by nabilultranet »
rich935 wrote: Sun Sep 20, 2020 12:58 am
Hope that helps.
Hello, you did PCM and TCM update, how long it takes you to do each update and what adapter did you use ?
Thinks for your contribution.
rich935
Post by rich935 »
nabilultranet wrote: Sun Sep 20, 2020 10:07 am
Hope that helps.
I have a 2013 Ford Focus SE and a ELS27 adapter and I think this adapter should be in FTDI mode not COM mode in the settings. For the PCM update it took about 35 minutes and for the TCM it took about 24 minutes. It took about twice as long as the estimated time. I have an older slow laptop and the ELS27 adapter says software on the Forscan website. viewtopic.php?f=16&t=14885
So if you have the Forscan recommended adapter OBDLink EX or the Ford VMCII it should be close to the estimated time or half the time of this one.
"Ford VCMII genuine with hardware ISO15765 – 1000Kb/min
OBDLink EX with hardware ISO15765 – 700-900Kb/min
ELS27 with software ISO15765 -200-300 Kb/min (on 2-8 Mbps baud rate)"
If you do try any updates make sure your computer doesn't go into sleep mode or something like that and it is plugged in and the car is hooked up to a battery charger just to be safer. It just takes a while to update but just be patient and let it finish and it should be just fine.
nabilultranet
rich935 wrote: Sun Sep 20, 2020 1:26 pm
Hope that helps.
Think you for your reply. I have an OBDLink EX and a LENOVO E330 I5 laptop.
I will give it a try but for the moment i'm not reassured.
Have a good night.
rich935
Post by rich935 »
Ok. If you do decide to o update the PCM and TCM maybe you can tell me how long it takes. Thanks 👍.
armsdigital
Vehicle: Fiesta 2014
Post by armsdigital »
How can we obtain the ford sync USB image update file?
its not available in the motorcraft service page.
nabilultranet
armsdigital wrote: Mon Sep 21, 2020 5:11 pm How can we obtain the ford sync USB image update file?
Maybe you need an "extended licence" so Forscan can request needed files from another storage location.
See part 3 of this post : viewtopic.php?f=16&t=14885
