Where to buy a compatible adapter?
janekj1985
Vehicle: Ford Mondeo mk3 2.0 tddi 115hp+
Re: Where to buy a compatible adapter?
Post by janekj1985 »
What do You think about interface for toyota & lexus mini-vci? It have j2534 and is compatibile with SAE J1850 PWM. I want use it for Mondeo mk3 '02 tddi. I have elm327 with bluetooth connection but I cant programm pcm. Is this possible that my elm is not compatibile with j2534?
azip01
Vehicle: Ford Escape 3.0L 2004
Post by azip01 »
janekj1985 wrote:What do You think about interface for toyota & lexus mini-vci? It have j2534 and is compatibile with SAE J1850 PWM. I want use it for Mondeo mk3 '02 tddi. I have elm327 with bluetooth connection but I cant programm pcm. Is this possible that my elm is not compatibile with j2534?
I have Toyota mini-VCI but I can not use it with Forscan.( I use Xhorse driver, Windows 10 32bit on VM VirtualBox.) If anyone can use this with Forscan, please tell us in this topic.
janekj1985
It would be cheapiest option for programming pcm if it work correctly :) Can You try to connect it?
edc
Vehicle: Ford F150 5.0 2013
Post by edc »
Would this one be a good one for Ford?
http://www.ebay.com/itm/Ford-USB-Super- ... 2269834510
fordman
Vehicle: fiesta 04 1.4 tdci
Post by fordman »
Hi yes that type of adapter is good for fords because it has the hs can and ms can switch.
idbooter
Vehicle: Fusion, 1.6T, 2013
Post by idbooter »
Would this adapter work with ford? Thanks.
http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... 2115168398
fordman
Post by fordman »
Hi
According to the spec it does covers the standard ford protocol. The modules on the Hs can bus would be accessible but not the one's on the Ms can bus (no switch). Bluetooth devices can be a bit hit or miss if they work regardless of specifications. I have had some that have worked and some that have not. Hope this helps.
idbooter
idbooter
Post by idbooter »
Thanks.
Just curious, if specs cover the MS CAN speed, 11*bit ID, 125*kbaud. Why do you need a switch?
[/u]
fordman wrote:Hi
fred08155
Post by fred08155 »
Ford uses an additional connection for MS-CAN on Pin 3 & Pin 11. This is not covered by standard OBD layout. So adapter needs to be modified for vendor specific diagnostics.
Standard OBDII pinout as specified
http://pinoutguide.com/CarElectronics/c ... nout.shtml
vendor specific pinout of Ford
http://pinoutguide.com/CarElectronics/f ... nout.shtml
Dmitriy32
Vehicle: Mazda 6 1.8 120л.с 2006
Post by Dmitriy32 »
https://ru.aliexpress.com/item/Diagnost ... -eub6yrrBy
вот этот заказал связывается с Forscan на ура Mazda 6 GG 1.8
