Page 5 of 7
Re: Method to disable auto stop / start found
Posted: Sat Mar 28, 2020 12:50 am
by Bourne
jejuda wrote: Thu Mar 05, 2020 3:20 pm Easy, Works on 2018 F-150 XL
FCIM Configuration Module
"Start/Stop Button Disable" Enable to Disable
IPC Configuration Module
"Auto Engine Shutdown with Memory" Enable to Disable
BdyCM As Built Module
726-48-02 x1xx to x0xx (first 4 digits)
Can the start/stop function still be enable when I press the start/stop button? I just want this function to be set off every time when I start the car. But it still can work when I need it.
Posted: Mon Apr 13, 2020 1:51 am
by Priscila.Guerini
I tried with your method seem like work fine, but i saw IPC show some message as bellow, what is the mean? Is BMS has been disabled also?
Airborne_Ape wrote: Tue Mar 07, 2017 7:17 am I'm sharing my test with the rest of you to use as a exactly that; a test, I can not guarantee anything.
All I can say is I figured it out on my 2017 F150 and it hasn't exploded yet.
2017 - F150 - Lariat 500a
Try at your own risk:
https://youtu.be/FQEn8U6A024
To summarize, I think a 100% auto stop/start disable would look something like this (I left my IPC stop/start message center enabled so I can still monitor it):
BCM 726-48-02 x0xx xxxx xx
FCIM 7A7-01-01 xxxx x0xx xx (optional - disables switch)
IPC 720-01-01 xxxx 1xxx xx (optional - disables stop/start message center on 2017 F150)
Please confirm if you encounter positive results in other Ford: vehicles, trim or model years.
Posted: Sun Jun 07, 2020 8:00 pm
by Elkingti
Hello, i can’t see the video. Can anyone repost the link of the video.
Thanks everyone
Posted: Sat Aug 08, 2020 11:54 am
by misiak
Bourne wrote: Sat Mar 28, 2020 12:50 am
I 2nd this! Is there a way to simply change the logic to deactivate start/stop at the beginning but still have the possiblity to press the button to activate it if needed? Simply after start the engine I want to see start/stop button light on. Do we want that much ? :) I don’t want to disable it completelly but simply to have it disabled after start so i don’t need to press the button after each vehicle start...
Posted: Sat Sep 26, 2020 10:30 pm
by msalerno
Was researching this for my daughter's new 2020 Escape SE just to see if it was doable. Could be, it seems...
As for the idea of it defaulting to off but still functional, a very simple circuit could be built that would close the circuit for a second, 30 seconds after getting power or whatever seems appropriate.
However, the install would be HUGE. Easier to buy that $99 defeat for it that plugs into the OBD-II port.
Posted: Thu Oct 22, 2020 9:41 pm
by chocohr
Anyone tried on a fiesta mk8 2019?
I tried on the ipc menú but it did nothing.
Posted: Thu Oct 29, 2020 5:25 pm
by chocohr
Anybody? :(
Posted: Fri Oct 30, 2020 9:53 pm
by VfrAndy
Video doesnt work. Can someone explain procedure for transit Custom 2014?
Posted: Thu Dec 10, 2020 2:32 pm
by germanunzner2
bigkuri wrote: Tue Sep 10, 2019 3:15 am Joined the forum just to post that this works in a 2019 Ranger Raptor.
Thank you everyone, I was hating the otherwise brilliant truck due to this, especially when it repeatedly stops with a stone cold engine - engines nor oil likes that at all.
Hey man, do you have the Values for that? Looking to disable that in a Ranger Raptor also.
Thanks, from Argentina.
Posted: Tue Dec 15, 2020 11:05 am
by ddiissaa
Hi guys.
I only seem to have BCMii 726-01-01 through 726-04-01. I have a 2014 focus. Can anyone help?
