ADD CLIMATE
Re: ADD CLIMATE
if yours is a uk spec car dont bother it wont work 100% aint worth the hassle
Re: ADD CLIMATE
turn in addtion the Navigation Repeater Format von Motorola to Intel to solve your messed up Nav distances on small screenReenmeister wrote: Thu Mar 07, 2019 7:09 amI have exactly the same settings + activated HWS and Heated Seats, but still the following side effects on my 2018 Fiesta:metalzone wrote: Wed Jan 17, 2018 9:17 pm Thanks to murat_kavuk, i got climate working on touch screen, without any negative side effect. These were the instructions:
7D0-01-02: xxxx x3xxx xxxx - Climate button + climate voice control
7D0-04-01: xxxx xxx0 xxxx - To see set temperatures on main screen (shortcut to climate setting window is climate button enabled)
Messed up Nav distances on small screen
No temperature display in climate control on right side (i know i don't have dual zone, but shouldn't the same temperature be displayed anyway?)
it seems to me as if climate in the footwell blows cold air all the time
Anybody has any idea?
Ford Focus MK4 YouTube Channel http://youtube.de/c/My-Ford-Focus
Reenmeister
- Vehicle: Fiesta 2018 1.0 EcoBoost ST-Line
Re: ADD CLIMATE
Ok, how can i set this?Focus-MK4 wrote: Fri May 10, 2019 9:48 am turn in addtion the Navigation Repeater Format von Motorola to Intel to solve your messed up Nav distances on small screen![]()
Re: ADD CLIMATE
Go to the APIM configuration and change it via the menu
roylion15
- Vehicle: Fiesta ST, 1500, Ecoboost, 200 PK, 2019 model
Re: ADD CLIMATE
Hello
Motorola or intel in the direct configuration doesn't change anything on my fiesta ST .
On the fiesta 2018/19 Set a "2" instead of a "3" ... the nav distance in the IPC display should be right now...7D0-01-02: xxxx x3xxx xxxx - Climate button + climate voice control
Reenmeister
Re: ADD CLIMATE
THX, was the right hint, but had to change from Intel to MotorolaFocus-MK4 wrote: Fri May 10, 2019 9:48 amturn in addtion the Navigation Repeater Format von Motorola to Intel to solve your messed up Nav distances on small screenReenmeister wrote: Thu Mar 07, 2019 7:09 amI have exactly the same settings + activated HWS and Heated Seats, but still the following side effects on my 2018 Fiesta:metalzone wrote: Wed Jan 17, 2018 9:17 pm Thanks to murat_kavuk, i got climate working on touch screen, without any negative side effect. These were the instructions:
Anybody has any idea?![]()
On my 2018 Fiesta (EU) nav distance in the IPC display doesn't work whether I set 1, 2 or 3. Additionally there are further side effects with 2 and 3. So the right setting is 1 + Navigation Repeater Format Motorola.roylion15 wrote: Tue Jun 25, 2019 8:51 am Hello
Re: ADD CLIMATE
Anybody have a solution for this yet? If not how can I remove climate options from screen but keep my dual zone working.
I can only have climate on screen and dual zone work but other way around. Or not display climate and dual doesn’t work both stay same temperature.
Re: ADD CLIMATE
Just a quick question regarding 7D0-01-01
I'm trying to retrofit a car without heated seats or steering wheel. Is this the correct parameter to change? Or is there another related to climate that I need to change?
consp
- Vehicle: Fiesta 125hp 2017 (My13.25 Mk7.5, With EU Sync3)
Re: ADD CLIMATE
Not surprised about that but I'm pretty sure this are the settings unless they changed them in later versions of the code:Reenmeister wrote: Fri Jul 05, 2019 3:36 pm On my 2018 Fiesta (EU) nav distance in the IPC display doesn't work whether I set 1, 2 or 3. Additionally there are further side effects with 2 and 3. So the right setting is 1 + Navigation Repeater Format Motorola.
bit 0 (value 1): 0 = motorola, 1 = intel
bit 1 (value 2): 0 = Surround sound in occupancy mode available, 2 = not available
bit 2 (value 4): 0 = Automatic Climate control, 4 = Manual or hard buttons
bit 3 (value 8): 0 = Man mode icon disabled, 8 = enabled. (I have no idea what this does)
So 1 or 3 would both be intel.
arisgardelis
- Vehicle: Ford Fiesta Vignale 1.5 TDCi
Re: ADD CLIMATE
Guys, did anyone see the option to change module settings?
I also struggled changing the number codes in the IPC, and I also had the same problem with the surround sound. But now that Forscan added ready settings, you just have to change the climate from manual to automatic (although your car is equipped with automatic climate, you have to declare it), and you also enable the climate controls. After these settings, the surround sound is still available.
Sorry for not giving exact directions, but it's prety easy to figure it out.
