Page 6 of 19
Posted: Fri May 26, 2017 3:18 am
by jzchen
I am new to FORScan as my wife's '13 C-MAX Energi just had a dead battery. I replaced it, but did not have means to reset the BMS. Luckily I saw on one modified ELM327 listing that you can try this in a "demo" mode and found the J2534 option. When first looking into Drew Technologies J2534 devices I was nervous to commit to an expensive CarDAQ Plus or CarDAQ M so I purchased a Toyota Mongoose Pro (blue) cable. I bought mine direct from Drew Technologies. I installed the driver on a Windows 10 (64-bit) computer that I haven't used FMP on. Then tried it with FORScan. At first it did not connect, but after selecting J2534 it did! I was so happy to find the BMS reset and reset it! Thank you!
I am interested in trying to enable the DRL function that is enabled on fleet vehicles. Will see what I can find with FORScan first. Still figuring where to buy an ELS27 to try with Focccus as well....
Feel free to let me know if I can help in any way!
Posted: Sun Jul 02, 2017 4:18 pm
by Wangstang
What does the VCM-II bring to the table that an authentic Ford original VCM leaves out when using FORscan?
Posted: Wed Jul 12, 2017 9:28 am
by SAMEER
HI CAN ANY ONE HELP I AM USING A VCMII INTERFACE. FORSCAN READS THE INTER FACE IN 1MS BUT DOES NOT CONNECT TO MY CAR SHOWS TURN IGNITION ON IT WORKED ONCE ONLY
Posted: Thu Oct 19, 2017 12:59 am
by Cossieman
Hi
Will try Forscan with original FoCOM/Fcom adapter, anyone tried it. What about VCDS and VAS adapter anyone tried it?
Posted: Mon Nov 06, 2017 4:24 pm
by kredka74
Hi!
I just try forscan with MAXISYS ELITE VCI thrue usb and j2534, all working fine and stable!
Regards:
Bob
Posted: Fri Nov 10, 2017 3:34 pm
by buckeyesvt
I have a Mac Mentor Touch with the Mac (Bosch)J2534 VCI and it works perfect over USB to use Forscan. Been using it for a couple of years now with no issues.
Posted: Thu Nov 30, 2017 4:35 pm
by juza
I have bosch kts540 tester what works allso pass thru device, but it say elm not found?
If go forscan setup there is no kts540 only 350 650 and some other ??
Posted: Thu Feb 01, 2018 6:50 am
by SAMEER
hi can some one please help i am using ford vcm 2 clone with forscan 2.3.12 beta when i start forscan it reads the vcm with 2 green ticks then windows crashes is there a known fix for this i am on windows 7 32 bit
Posted: Sat Mar 24, 2018 4:12 pm
by Paullk8232
So I have a Kvaser USBcan pro 2xHS v2, it shows up as a J2534 device but having some trouble getting FORScan to make a connection. I also have ATI CAN LAB, I was able to connect to one bus, I think this was the accessory bus, pins 3 and 11, I can make the connection but must set this to 250kbps. I was trying to use the port of the adapter on 6 and 14, not seeing anything there yet. I used to mess around back in the day with tuning but I have been out of this for a while, I bought this software for work. I do automation involving PLCs and diesel engine control over J1939, along with tons of other stuff rs232,rs485/422, I used to have to program my PLC and can gateway to grab a block of messages, write them down and decode by hand. I'm using my truck 2016 f350 diesel to get familiar with the software and would appreciate any advice. Thanks.
Posted: Sat Mar 24, 2018 4:14 pm
by Paullk8232
I should also not that I do have a ELM device and it works correctly with FORScan
