Testing firmware update function for Ford modules
mschumiv
Vehicle: Ford Focus MK4 1.5L 88kw diesel 2019
Re: Testing firmware update function for Ford modules
Post by mschumiv »
Anyone with a mk4 here?
I flashed the DDM and RCM module, all went well but some functionality changed. Since i wasn't able to flash the PDM module due to some service interrupted error, the windows on the left behave differently than the ones on the right, when using Global close. The left ones close fast at first and on the last 5 to 10 cm, really slow.
I've also lost some selective unlocking features like the ability to unlock only the trunk while the doors remained locked (using the keyless entry feature). Now all doors unlock when trying to open the trunk.
I didn't mess with the anything else but somehow the steering seems to be affected, the level of electrical assistance seems lower, and requires some little extra force to steer.
omar302
Post by omar302 »
I have a 2016 Edge Sport (2.7L Ecoboost). I am also interested in testing. Thanks.
typhoonf2
Vehicle: ford focus 1.6 tdci 2013
Post by typhoonf2 »
I am also interested in testing, I have a mk3 focus tdci. I also have ford UCDS and a genuine els 27 from Russia plus an elm 327. Thank you.
davetcollection
Vehicle: Focus 2017 ST-Line 1.0 Auto 6F15
Post by davetcollection »
I would really like to be able to have the update function.
I have a Fiesta 2018 1.0 (100) Ecoboost Automatic ST-Line X
Focus MK3.5 1.0 (125) Ecoboost Automatic St-Line
Focus MK4 1.5 Ecoblue Diesel (120) Manual Titanium
I am eager to keep the PCM and TCM softwares up to date on the Automatics, especially the MK3.5 Focus as it's about to go out of warranty
Using ELM 327 Modded
mschumiv
Post by mschumiv »
davetcollection wrote: Mon Oct 07, 2019 6:49 am I would really like to be able to have the update function.
Work is in progress, support for Focus mk4 is limited at the moment; not all updated files are available from Ford server, some require paid subscription.
You should avoid messing with the PCM, as you may loose data, that only Ford IDS can reprogram. Best scenario, you get increased consumption.
davidtanis
Vehicle: Ford Fusion 2.5 SE 2015
Post by davidtanis »
Can I still join? 2015 Fusion SE
LaForge
Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
Post by LaForge »
mschumiv wrote: Wed Oct 02, 2019 8:19 pm Anyone with a mk4 here?
Dear friend,
Do you have done a full recalibration of your doirs?
Before that you have to reset your module to default and then do a relearning of all desired and needed features.
With my mk3 i ve got similar issues after reflashing the ddm and pdm module
Best regards
Karsten
Changed on my 2011 Focus:
Hill Assistant, Auto High Beam, Sync 3 with Navigation, Traffic Sign recognition, Lane Keep Assist,
Lane Centering Aid, Rain Sensor, Ambient & Footwell Light, FL ST-IPC, BLIS, HSW from Focus FL.
mschumiv
Post by mschumiv »
LaForge wrote: Sun Oct 13, 2019 5:06 am
Dear friend,
Best regards
Karsten
I've downgraded back to original firmware and all is ok.
I still can't flash the PDM module.
gravey
Vehicle: Kuga, Euro 6 TDCI 2.0, 2016
Post by gravey »
Hi.
Any chance I can get this to try on a 2016 kuga?
districtluke
Vehicle: MONDEO TITANIUM X
Post by districtluke »
I would like to test 2.4, working on vbf uploads to sync 3 to enable 3.4 installation with dab logos etc. Working on a focus mk3 pre facelift with els27, elm27, Ucds cable and ids access if needed.
Many thanks
