Region And Language for APIM and IPC
3ANON
Vehicle: Ford galaxy 2.0
Re: Region And Language for APIM and IPC
Post by 3ANON »
Good evening!
Hungarian language code?
And if I type it, it will be Hungarian, for example. km hour menu.
praded2007
Vehicle: mazda cx-5
Post by praded2007 »
HUNGARY (HU)
Set to 4855
commpact
Vehicle: Ford edge 2.0 154KW BiTurbo
Post by commpact »
Hi, Forscan writes that my country code (Czech Republic) EZ. That should be 455a. But 455A is already entered in the IPC, but the Czech language is not displayed. Is the code of the Czech Republic really EZ? Or where there may be a mistake. Thank you very much for your answer.
zmort
Vehicle: Ford Mustang 2.3 2018
Post by zmort »
Good day! I have 2 mustangs of 18 and 20 years old, in which the factory language pack is weak, and I cannot activate the necessary languages by changing the region because they are not in this firmware! can someone help here are my parameters of the IPC module(20g) KR3T-10848-AD : JR3T-14C025-AC , KR3T-14C026-AD, KR3T-14C088-AC and IPC module(18g) JR3T-10848-AF : JR3T-14C025-AB, JR3T-14C026-AE, JR3T-14C088-AD Can anyone tell me what files can be updated??? I would be very grateful
zmort
Post by zmort »
I need to add Russian, thank you very much!
Focusfordmk3
Vehicle: Ford Focus pnda 125 le
Post by Focusfordmk3 »
Sziasztok! Tudnátok segíteni hogy hogyan lehet mondeo mk5 sync 3 magyarosítani a kijelzőt és fedélzeti kijelzőt? És hogy hova milyen kódot írjak be?
Focusfordmk3
praded2007 wrote: Tue Feb 22, 2022 7:53 pm HUNGARY (HU)
Set to 4855
Helló! Tudnál segíteni hogy hova kell beírni a kódot hogy magyar legyen a km óra és a gps? Köszönöm szépen!
Focusfordmk3
3ANON wrote: Sat Feb 19, 2022 8:13 pm Good evening!
Szia! Melyik mezőbe kell beírni a kódot hogy magyar legyen a műszerfal és a navigáció? Köszi!
Focusfordmk3
Melyik mező az országkód?
stala
Vehicle: Ford Escape 2021 2.0EB 4x4 2017
Post by stala »
good evening. anyone has codes to change the language to clocks and sync and radio stations on Eu in Escape 2020 region PL Poland
