Where to buy a compatible adapter?
Blackhawk2012
Vehicle: 1999 ford E350 7.3 Powerstroke Econoline
Re: Where to buy a compatible adapter?
Post by Blackhawk2012 »
I have a 99.5 E350 van and bought kobra elm327 wifi from amazon and it does not work. I have iPhone and android. I can see obd2 but it will not connect. Used a free app for testing and it says weak signal, it will connect but not show anything. When I start van and hit diagnosis it will kill engine. Any recommendations?
ThatOneDude
Post by ThatOneDude »
Whatever you buy, make sure it specifically says it works with the Medium Speed Controller Area Network (MS-CAN) Bus for full support. I personally use the OBDLink MX Bluetooth.
RickyBobby
Vehicle: 2014 Ford Escape SE 2.0L
Post by RickyBobby »
Also made the mistake of purchasing a cheap, $5., chinese ELM327 clone from eBay to use with FORScan and my 2014 Ford Escape. It has V1.5A on the label but uses an old Prolific PL-2303 chip. It may load the adapter in Windows 7 with the old drivers but not in Windows 10 that uses newer drivers. When you connect the adapter and check device manager you will see a yellow exclamation point next to Prolific USB-to-serial Comm port. You have to downgrade the driver to an earlier version. You can get the older driver from here: http://www.totalcardiagnostics.com/supp ... 2-software In step 1 choose Windows 8, 10 and download Driver Pack 5. After installing the older driver FORScan saw the adapter on COM 3 but when I hooked it up to my Escape, key and/or engine on, I got the dreaded "Unable to connect to vehicle. Please make sure the ignition key is ON and try again". I contacted the ebay vendor, expecting to be blown off, but he was kind enough to refund me the 5 bucks. It may work with another vehicle but not with a newer Ford Escape.
Another cheap chinese ELM327 clone.
https://imgur.com/Bzmanrw
I was going to go with Scantool's $80. OBDLink MX adapter but on the Escape forum someone posted that this adapter also works with the newer Ford Escapes and FORScan. https://www.amazon.com/OHP-ELMconfig-co ... iagnostics
I also found this adapter that's cheaper than the OHP and uses the exact same FTDI chipsets. https://www.amazon.com/bbfly-BF32301-EL ... CAN+Switch
https://www.aliexpress.com/store/produc ... 98242.html
FTDI updated Windows' drivers: http://www.ftdichip.com/Drivers/VCP.htm
So I'm going to give the bbfly-BF32301 adapter a try and will report back with the results.
Ronald53
Vehicle: Transit Mk7, 2012, 125hp, EuroV
Post by Ronald53 »
This one definitely is s*h*i*t, it does not connect to FORScan Lite : https://www.aliexpress.com/item/Mini-EL ... 0.0.2iC4VK
And this one does connect! https://www.aliexpress.com/item/Vgate-i ... 0.0.vltvFx
The app ELM327 Identifier displays 100% compatibility with protocols 1.0 - 1.4 and 0% compatibility with 1.4b - 2.2.
Ronald
ghades
Vehicle: ford f150 xlt blk 2015
Post by ghades »
Hello
hey guys I just bought this adapter from ebay https://www.ebay.com/itm/New-ELS27-FORS ... SwC~tZjXTz
how do I know if its good adapter or not so far the only thing I've done is connected to my truck read everything ok with no problems just asking before I do any changes to my truck
RickyBobby
Ordered the bbfly-BF32302 from AliExpress for $17.55 shipped. https://www.aliexpress.com/store/produc ... 98242.html Delivery time was 12 days. A little bit cheaper than Amazon and no sales tax. It also comes in a blue tooth version for a few bucks more.
The USB cable (6' long) version works great with my HP 10" tablet running Win 10 Pro 64 bit V.1709, ForScan, and my 2014 Ford Escape. No need to purchase the $80. OBDLink MX. I didn't see any conflicts in Device Manager when I plugged it into my tablet but to be current I downloaded and installed the latest FTDI chip driver. http://www.ftdichip.com/Drivers/VCP.htm Only con is there are no markings on the switch for what protocol you are in. MS Can is the left position and HS Can is the right. ForScan will tell you to flip it if it is on the wrong setting.
Icecoldak
Vehicle: 2018 F-150 Limited 3.5EB
Post by Icecoldak »
I went ahead and bought my scan-tool OBDLink Mx bluetooth right from scan-tool.net, they have them fro $79 shipped, I figured I would not waste my time with these cheap chinese knockoffs and bypass all the frustration!!
*voyager*
Vehicle: 2013 Interceptor 3.7L
Post by *voyager* »
Well, I am getting NOWHERE.
I ordered this unit:
<<https://www.ebay.com/itm/USA-Ship-Super ... 2749.l2649>>
And while the driver installed and it shows on COM4, I get a "No ELM FOUND" when I try to connect. I purchased this specifically based on an article to do exactly what I wanted to do (enable keyless entry on my 2013 interceptor and make a couple other improvements)
OK. It's not compatible with FORSCAN despite what the poster said, so I purchase this:
<<https://www.ebay.com/itm/VINT-TT55502-E ... SwhMpZpLiU>>
It's SPECIFICALLY "MODIFIED FOR FORSCAN". Windows can't find a driver for it, no driver CD was included, and the link to the driver is a dead page.
WTF?
Does anyone know how I can get EITHER of these interfaces working?
And will they extend my trial of FORSCAN extended since I have yet to be able to actually USE it?
RickyBobby
@voyager
Vint and bbfly are the same Chinese company. The VINT-TT55502 and bbfly-BF32302 adapters look identical and probably are clones of each other out of the same Chinese factory and use the same chipset. You can try downloading and installing the drivers for your OS from here: http://www.ftdichip.com/Drivers/VCP.htm
*voyager*
Post by *voyager* »
Did you look at the links? These units look nothing alike and the latter was modified "to work with Forscan".
I am fairly certain those are the drivers that are installed for the first unit. The second does not recognize them, and the nano keeps giving me a "No ELM Found" error.
But I appreciate your reply. Today is again the last day above freezing, so it looks like I won't be able to try it for a few more weeks.
I can anticipate a fight with Forscan to try the SW, as it will likely expire before I can try it.
Or are you saying the driver listed is for the bbfly unit and may work with the VINT?
Update: That is the driver loaded for the first one. It shows as COM4, but Forscan keeps giving me the "NO ELM FOUND" error after the "checking COM4" message.
Update 2: That driver does not work on the second unit. Device Manager identifies it as "USB2.0-Serial". You would think the internet search would find a driver for that since there are so many USB-Serial devices out there.
