Region And Language for APIM and IPC
Don Ridley
Vehicle: 2016 Transit Connect
Re: Region And Language for APIM and IPC
Post by Don Ridley »
stala wrote: Tue Apr 19, 2022 6:39 pm good evening. anyone has codes to change the language to clocks and sync and radio stations on Eu in Escape 2020 region PL Poland
TUYU
Vehicle: FOCUS-MK2.5-125KW
Post by TUYU »
What is the Taiwan code of apim please. Thank you
dan9405
Vehicle: ford focus mk1
Post by dan9405 »
Sziasztok!
Egy olyan problémám lenne az új Ford Focus mk3 face lift verziós kocsival hogy nem magyar az IPC és a APIM.
Ebben kérnék egy kis segítséget.
Vissza olvastam amit írtatok és nekem hiányzik ez a mező
IPC 720-04-02 504C xxxx xxxx
Hello!
One problem with the new Ford Focus mk3 face lift version car is that IPC and APIM are not Hungarian.
I'd like some help with that.
I read back what you wrote and I miss this field
https://kepkuldes.com/image/UDrtPV
dan9405
Post by dan9405 »
Valaki tudna segíteni ?
Magyarra szeretném állítani a fedélzeti számítógépet illetve a navigációt a naviba (APIM) be van állítva a 4855 de az IPC-ben nem tudom hova kellene beírni vagy hogy hol lehetne
JC3
Vehicle: Bronco Sport 2021
Post by JC3 »
I imported a new Bronco Sport from the US to Germany. It comes only with the US maps and languages. I found some topics, but nothing changed after I made the changes.
I hope that someone can help me.
Thanks and greetings from Germany.
Top
bakutyl
Vehicle: Mustang Mach-e GT 2021
Post by bakutyl »
How to change US to EU in mustang Mach-e sync 4 ? Many thanks
v8mustang wrote: Tue Mar 02, 2021 9:06 pm Hello
To change the language and region on a US mustang, you have to change the following
ACM 727-04-01 x3xx xx50 4Cxx
3 = Europe---- 504C = your country code PL the (x) you must left the original numbers
FCIM 7A7-01-01 x4xx xxxx xxxx
4 = europe
APIM 7D0-01-01 xxxx xxxA 3xxx
A = DAB on ------- 3 = RDS EU
APIM 7D0-02-01 504C xxxx xxxx
Hope this Helps
dan9405
Post by dan9405 »
bakutyl wrote: Sun Jul 10, 2022 6:37 pm Hello,
4 = europe
Hope this Helps
it's not good for me, I tried it, but I'm missing the 720-04-02 picture at the IPC, but it's not there
bakutyl
Post by bakutyl »
Many thanks.i will try tromrrow.
Where I can find how to turn on rear fog light in forscan?
midax
Vehicle: Ford Mustang
Post by midax »
bakutyl wrote: Wed Sep 28, 2022 6:49 pm Many thanks.i will try tromrrow.
in BCM module.
dotlukasz
Vehicle: C-MAX Energi 2015
Post by dotlukasz »
I have a C-Max Energi 15y from USA. I change in APC, APIM and IPC from 5553 to 504C and I have a polish language in instrument cluster but not in Sync2. What should I do more? I havent FCIM in Forscan.
