Page 9 of 12
Re: Region And Language for APIM and IPC
Posted: Tue Apr 19, 2022 11:18 pm
by Don Ridley
stala wrote: Tue Apr 19, 2022 6:39 pm
good evening. anyone has codes to change the language to clocks and sync and radio stations on Eu in Escape 2020 region PL Poland
- poland.JPG (16.27 KiB) Viewed 4885 times
Posted: Wed Jun 01, 2022 11:49 pm
by TUYU
What is the Taiwan code of apim please. Thank you
Posted: Sun Jun 26, 2022 5:07 pm
by dan9405
Sziasztok!
Egy olyan problémám lenne az új Ford Focus mk3 face lift verziós kocsival hogy nem magyar az IPC és a APIM.
Ebben kérnék egy kis segítséget.
Vissza olvastam amit írtatok és nekem hiányzik ez a mező
IPC 720-04-02 504C xxxx xxxx
Hello!
One problem with the new Ford Focus mk3 face lift version car is that IPC and APIM are not Hungarian.
I'd like some help with that.
I read back what you wrote and I miss this field
https://kepkuldes.com/image/UDrtPV
Posted: Fri Jul 01, 2022 8:13 am
by dan9405
Valaki tudna segíteni ?
Magyarra szeretném állítani a fedélzeti számítógépet illetve a navigációt a naviba (APIM) be van állítva a 4855 de az IPC-ben nem tudom hova kellene beírni vagy hogy hol lehetne
Posted: Mon Jul 04, 2022 11:12 am
by JC3
I imported a new Bronco Sport from the US to Germany. It comes only with the US maps and languages. I found some topics, but nothing changed after I made the changes.
I hope that someone can help me.
Thanks and greetings from Germany.
Top
Posted: Sun Jul 10, 2022 6:37 pm
by bakutyl
How to change US to EU in mustang Mach-e sync 4 ? Many thanks
v8mustang wrote: Tue Mar 02, 2021 9:06 pm
Hello
To change the language and region on a US mustang, you have to change the following
ACM 727-04-01 x3xx xx50 4Cxx
3 = Europe---- 504C = your country code PL the (x) you must left the original numbers
FCIM 7A7-01-01 x4xx xxxx xxxx
4 = europe
APIM 7D0-01-01 xxxx xxxA 3xxx
A = DAB on ------- 3 = RDS EU
APIM 7D0-02-01 504C xxxx xxxx
Hope this Helps
Posted: Sat Jul 16, 2022 5:53 am
by dan9405
bakutyl wrote: Sun Jul 10, 2022 6:37 pm
Hello
4 = europe
Hope this Helps
it's not good for me, I tried it, but I'm missing the 720-04-02 picture at the IPC, but it's not there
Posted: Wed Sep 28, 2022 6:49 pm
by bakutyl
Many thanks.i will try tromrrow.
Where I can find how to turn on rear fog light in forscan?
Posted: Thu Sep 29, 2022 6:25 am
by midax
bakutyl wrote: Wed Sep 28, 2022 6:49 pm
in BCM module.
Posted: Sun Oct 02, 2022 5:37 pm
by dotlukasz
I have a C-Max Energi 15y from USA. I change in APC, APIM and IPC from 5553 to 504C and I have a polish language in instrument cluster but not in Sync2. What should I do more? I havent FCIM in Forscan.
